Sedan with Nismo LMGT4 wheels? Offset help!
Hello everyone, I am looking at picking up a set of Nismo LMGT4 wheels and have a few questions. The sizes are 19x9.5 30mm offset all aound non staggered. I have been searching all night trying to find a car with a simular setup, and I have seen some that have fronts that match, and some that have rears that match. But never a none running that profile wheel at all 4 corners. I am looking to add a drop with tanabe, or eibach springs.
My first question is, will I run into fitment issues? Please correct me if I'm wrong, but I think from running the calculator, the fronts will be fine, and I could even run 10mm spacer. What about the rears though?
My second question is, what tire sizes would be best?
I appreciate your time, and help. I have been researching and racking my brain countless hours for the last 3 days.
First running non staggered is fine, and you shouldn't worry about fitment it will fit both front and rear. Even with the eibach drop it's good offsets. The tires you can run all around are 255/35/19 and you might not need spacers for it to be flush with the fender.
Contact ChinkyChoy over on 'Driver. He may be able to offer you some insight. In fact he has his own set for sale, too.
http://g35driver.com/forums/5855350-post147.html
So just an update, I did not end up getting that set, but I currently am about to purchase a set of Nismo LMGT4 FR: 8.5 x 18" +25 RE:9.5 x 18 +30. I have tried toying with the wheel and tire calculator but I just don't get it. I think I have a learning disability when it come to offsets, and fitment. Any help would be appreciated.
Thank you for your input. Unfortunately they were stolen from the gentleman I was going to purchace them from. My quest for lmgt4s continues.
Even lower offset wheels can easily be fitted. The million dollar question is what kind of tires are you looking to pair them with? Meaty and beefy tires (tall&wide) or skinny/low profile tires?
