installed coupe 19's on sedan, quick question
Here is the visual if you were to take the tires completely off the wheel and swap them. The benefit is the inside that had camber wear will now be on the outside.
PSS tires are assymetric non-directional. Dismounting them then re-mounting them to an opposite side would still mean the marked "Outside" wall will still face out. Theoretically you can have the outside wall face in, as in how you described it, but it will affect how the tire performs -- especially with the PSS where 3/4 of the inner tread is an all-season compound and the 1/4 outer tread is a summer compound with larger blocks for cornering traction.
The method you mention usually only applies to directional tires like the Hankook V12's, which does not specify an outside or inside wall.
With a staggered PSS set-up, you literally flip the entire mounted tire/wheel onto the other side and it's the same thing as dismounting the tire and re-mounting it, but without the extra hassle and cost.
hey guys, sorry it took so long.. but here are pics! theyre just quick shots, but i also included some closeups. for those wondering these 19's went straight on without any modding, along with the PSS of course.
i went with a color the shop had, it was called bengal silver. i pretty much just brought the guy out to my car and asked what color they had that was closest to my OEM 17's, and he recommended the color i have now. they were really cool, i started with a light gray but it turned out really weird, so they redid it for me.
I did not know the PSS were made that way. Interesting. They seriously don't want you getting more than 10k out of your tires then, so I guess performance is considered priority number 1. However, my assumption is most Ferrari owners could care less about those two things anyway.
i havent driven around too much yet but there are no complaints. im no expert so i dont think i could give sound judgement on handling other then it feels very very good. it feels like it takes less effort to turn, and it just feels like the car is glued to the road.
superjoey
31
03-22-2023 11:56 PM
