Free tires, worth it to swap?
I'm new to my G and cars in general, so please bear with me!
I'll do pretty much anything to get the stock RS-A's off of my G37x. A good friend of mine had new wheels put on his 5 series and had to ditch his tires for a different size. He'll give me those tires, a set of practically new Nexen N5000 225/50/R17 93H tires for free.
Will the different size be an problem at all? My limited knowledge says no, but I want to double check that. Does anyone have any first hand experience on how these would perform relative to the RS-A? Opinions/other thoughts? I do quite a bit of driving in Upstate NY lake effect rain and snow, and I'm hoping to get better traction in the bad weather with the switch.
Thanks in advance!
Thanks in advance!
Just say no!!!!!
It's a korean made tire, available at walmart.
IMO, you get what you pay for. The kia optima sx i had came with some sort of high performance nexens - what a joke. I associate nexen with junk. Ebay or CL them for some cash.
You don't specify what size tires your car currently has, but assuming it's a square set up, they'd work, but might mess up your speedometer/odo if the diameter is larger/smaller. Also, I think the minimum load rating required is 95 given the weight of the car.
Get some real snow tires for winter driving.
Currently have 225/55/R17. How far would they throw off the instruments?
I want to stick with an A/S tire. If these turn out to not be worth it (or plain won't work due to the weight issue), I'll spring for a set of Continental DWS's.
