Ideal Rims G37x Sedan
Old 07-12-2012, 09:41 PM
Mike@Vossen
SUPPORT AUTHENTICITY!
Mike@Vossen's Avatar
I just posted in this thread. Very well done.
https://www.myg37.com/forums/picture...ghlight=Vossen
Old 07-13-2012, 04:32 AM
Rocket Jockey
Rocket Jockey's Avatar
VMR V710's and Swift Springs
As promised, here are a couple pics......19" VMR V710's dropped on Swift X Springs. The pics do not do the car justice. Tough to see the fender to tire height on a black car. Everyone likes/wants something different....I wanted a conservative daily driver with a square set-up that I can rotate and don't have to worry about the AWD having any issues since am still under warranty.
Do not cut factory springs. The Swift X springs were designed specifically for the X sedans. Super easy install....easier than the non-X sedans.
RJ
Old 07-13-2012, 08:16 AM
Received 4,943 Likes on 4,176 Posts
RJ
Looks great, that's the way to lower an X, close the gap but still keep it high enough that it's an easy daily driver. Those Swift springs really do the job well, nice wheels too!
Old 07-13-2012, 10:45 AM
sniper27
sniper27's Avatar
RJ
looks great. did you get the 19x8.5? what offset?
Old 07-13-2012, 10:57 AM
Rocket Jockey
Thanks! Yep, 19 x 8.5 with a 35 offset. That is the only offset they offer right now in the 8.5" with our bolt pattern which is probably perfect for a square set-up anyway. They have a 9.5" with a 22 offset but that was more aggressive than I wanted and you would need to run some negative camber to tuck the rear.
Old 07-13-2012, 11:02 AM
sniper27
sniper27's Avatar
hmmm...i don't think i will be lowering the car, so +35 might poke out a tad with stock RWD suspension.
Old 07-13-2012, 12:09 PM
Rocket Jockey
You are running the coupe 19's correct?? I think those rears are 8.5 with a 45 offset.....correct? That would mean an 8.5" with a 35 offset would be less than 1/2" (0.39) wider at the fender. Do you have that room? I am definitely inside of flush with the V710's running less than 2 degrees of negative camber.
For what it's worth, I think your car looks great with the coupe wheels.
RJ
Old 07-13-2012, 12:18 PM
sniper27
sniper27's Avatar
Thanks...yes, I have the coupe wheels and I love the way they look with stock rwd suspension. The rears are 9in with 45 offset. So with the VMRs, the rears would poke out additional 4mm. The fronts are 8.5 with 43 offset, so the VMRs would stick out addtional 8mm. I guess it's not much and could work. But would still like to see them on the car first.
Old 07-13-2012, 12:22 PM
drizzy315
drizzy315's Avatar
Thanks guys nice set up bro so 35 offset is best fit ? What would be ideal offset like i eould like wheels stick out a bit?
Old 07-13-2012, 12:31 PM
Rocket Jockey
Knock yourself out playing with the offset calculator!!! If you are running stock wheels you can do a search for width and offset then just plug in the info on whatever other wheels you are considering. Remember camber will affect how the wheels tuck.
Wheel Offset Calculator
RJ
Old 07-20-2012, 10:34 AM
ATC_24
ATC_24's Avatar
Rocket Jockey, very nice setup. I believe I'm convinced lol. I haven't even picked up my car yet(G37XS) and I want to change out the wheels and springs. Can you confirm your not using spacers and the 35 offset is will do the trick. We get a fair bit of snow up here and have some rough roads so I cant be too aggressive with the drop and how flush the wheels will be with the fenders. I'm in the same boat as you with the AWD and the conservative DD mentality/warranty issues.
Old 07-20-2012, 02:14 PM
Rocket Jockey
I am not running any spacers.....and don't want to run spacers. In my opinion, a 35 offset with an 8.5" or even 9" wheel running a 245/45/19 is the best on a 19" square set-up.....no poke......no rubbing.
I originally ordered Forgestar F14's and they can custom cut the offset to anything you want and they recommended a 35 offset as the best for a square set-up with their 9" wheels.
I am happy with my set-up,
RJ
Old 07-20-2012, 02:47 PM
ATC_24
ATC_24's Avatar
RJ
Thanks. Your set up looks great to me as well.
Old 07-24-2012, 02:18 PM
  #29
mystikal
mystikal's Avatar
Before
After:
Tires
245-35-20
275-30-20
20x9 offset 32
20x10.5 offset 42
11 g37x on Eibach pro springs
Here's how mine looks...No rubbing at all...
Personal preference to what size you want either 19" or 20" or 21"....
Old 07-24-2012, 05:19 PM
  #30
sniper27
sniper27's Avatar
man, the X is so much higher stock than the rwd.
Quick Reply: Ideal Rims G37x Sedan
