Will they fit?
Will they fit?
I need your help! I was offered a good price on a used set of Lexani LSS-5 rims but I'm not sure if they will fit.
Front 20x8.5 245/35/20
Rear 20x 10 275/30/20
He thinks...the offset is +15
I have a 2012 g37s coupe that will be lowered on Eibachs.
It's a long way to go do a test fit!
Thanks.
Thanks.
There are three sorts of fitment issues you need to worry about (in order of importance)
1) Bolt pattern. Are those 114.3 x 5?
2) You have an S model, will those clear the OEM Brakes? (Check with seller/shop)
3) Offset is not something he thinks, he needs to find it out or measure it for you. Otherwise you'll never know how it would fit with respect to your fender. +15 on a 8.5 (front) is fine. On a 10" wheel (rear) would be pushing it.
37
10-17-2020 11:12 AM
ck1109
10-15-2015 11:06 PM
