Are Michelin PSS much better than Dunlop SP Sport Maxx A/S?
Yes, they are "better".
Are they worth the extra cash to you? Only you can decide that
If you want to compromise, the Michelin PS A/S Plus is a FANTASTIC All Season tire. They'll last way longer and give amazing performance for an all season tire.
I understand going a little lighter, but you can go lighter and still get fat tires up front with Rays/Volk and a few others, too, and stay the same size/offset to rotate... which saves tire wear... which saves MONEY.
Can anyone explain to me why you would want a staggered setup, other than weight reduction??
Wider rear tires help provide more grip to the rear, which tends to break loose. Properly set-up, it also provides more lateral grip -- however, this only works if the rear track is actually narrower than the front.
Most people will do the flush set-up, which pushes the rear track to the same width as the front, or more, which does more harm than good when it comes to performance. Fortunately, people who do this are going strictly for looks and will never push the car to the point that this difference is felt behind the wheel.
The differences in widths help with understeer/oversteer corrections.
understeer / oversteer corrections
Personally, i run a square set-up as well, and make the necessary corrections via tire pressure, sway and coil/damper adjustments. I find this to be a better way to go, personally, on the track. And it makes it a very practical way to go for daily driving as well.
Just to add, weight reduction is likely not a reason for it. True, the fronts may be lighter, but on our cars the rears are what need that reduction the most as they're the drive wheels. But in this day and age of going 20s and going as wide on tires as possible, that concept is lost.
Thanks for the clarification. My car is a daily driver, but I do occasionally put her through her paces, so to speak.
I went with 20x9 +32 all around, but it IS more for looks because the wheels I went with actually added weight. (I plan to fix that eventually)
With the wheels/coils I have the car most certainly handles better than it did stock.
It actually doesn't matter if the front or rear wheels are being driven... If you lighten any axle, the reduced inertia will improve acceleration because all axles have to spin as the vehicle moves.
Of course, once all wheels are moving, the lighter weight is felt more in terms of braking, suspension and steering performance.
footballmania32
09-04-2015 03:06 PM
