What is everyone's thoughts on the new WORK Gnosis CV201? I'm digging them and PMed RavSpec for pricing. Need help picking perfect offsets. I'm still leaning towards Dagon68 set-up except a 285/35 vs his 295/30;
19x9.5 +32 255/40
19x10.5 +45 285/35
Those should look really nice on your Blue Slate, offsets seem pretty good.
My 20X10 +45s are just about perfectly tucked just inside the fender lip w/ my 295/30/20s, so your 285s on a 19" +45 should be pretty similar.
Rob, are you planning on running close to OEM camber?
Remember, i'm on Swift now, too. My front 18x9.5+38 extends beyond the fender lines by a few mm. The 255/45 tires make it less apparent due to the slight stretch. This is with camber on the lower-end of OEM spec.
Yes I want to keep it OEM/square as possible. You suggesting to take it back some? You have a pic of your fronts?
Any chance you'll be back home anytime soon? It's best viewed in person. It's extending just slightly, but not very noticeable since the tire is a bit stretched. Depending on the angle you're viewing it, it's either OK, or poking a little.
Won't be home till May. Maybe I'll request a +35-40 and add small spacers. What I had to do with my old WORKs for my Z.
