Wheel & Tire Brand(s) Chosen - Help With Sizing?
rpm&my_G35 has good tire combos for your X, the diameter for the 245s is virtually identical to your stock tire and the 275s are only 5mm shorter (a 0.93% difference). Should work fine on your AWD, and look nice too ![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
Here's a nice tire calculator if you want to check sizes out yourself~
Tire Size Calculator - tire & wheel plus sizing
