TPMS Compatibility and Syncing Questions
I've done some searching on the forums for answers, and have found some conflicting information, so I thought it was best to start a new thread and get current info...
I'm looking into getting a second set of wheels/tires for summer for my 2009 G37x Coupe.
I'd like to not have to worry about swapping TPMS each time I swap the wheels.
The questions:
Can the car have more than one set of TPMS sensors synced to it?
Will newer sensors from a 2010+ G37 work with my 2009 G37x?
How does the syncing work? Can I do it myself, or does it have to be done at a tire shop/dealer?
The questions:
The questions:
yes, i believe so
no, i don't believe so. there was a change made in late-2010.
yes, i believe you can do it yourself. there is a guide on here somewhere but a tire dealer should be able to do it cheaper than a dealer as well.
The questions:
yes, i believe so
answers in Bold
lol, more conflicting information.
Assuming the maximum of 4 synced sensors is correct, are there sensors that can clone the IDs of other sensors so that wheels can be swapped without needing to resync?
There is no conflicting information. There are four slots in the BCM memory for remembering sensor ID, one for each wheel:
ID REGST FL
ID REGST FR
ID REGST RR
ID REGST RL
Each slot will only remember 1 sensor ID. As soon as you program a new one, the old one is replaced. Simple as that.
No, there are no sensors that can clone IDs.
ID reprogramming is DIY job.
https://www.myg37.com/forums/d-i-y-i...-for-free.html
ID REGST FL
ID REGST FR
ID REGST RR
ID REGST RL
The conflict was between what you and rks said about more than one set of sensors programmed in. Your info appears to be definitive. The reprogramming thread is very useful. I'm glad that it doesn't require a dealer visit to swap tires...
I stand corrected. There is a product that copy OEM sensor ID into a new sensor. However, I dont think its worth the money or trouble:
T30 - Diagnostic Tools by Orange Electronic
Now I'm really glad I didn't buy those wheels & tires!
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
![](/images/premier.gif)
Guess you missed the thread I posted the other day! ![Icon09](https://www.myg37.com/forums/images/smilies/icon09.gif)
I put these on my DPE wheels!!!![Biggthumpup](https://www.myg37.com/forums/images/smilies/biggthumpup.gif)
https://www.myg37.com/forums/vendor-...nics-tpms.html
04G35NYC
12-24-2015 01:00 AM
