vossen cv3 help
Old 04-21-2012, 10:27 PM
xsonnixx
xsonnixx's Avatar
vossen cv3 help
hi im looking to buy a set of cv3s and im drop'd on eibach PK for AWD now i want a semi agressive look i dont want it to be too tucked i know the +20f+25r will look stupid with eibach pk drop what if i get +32f+45r vossen and add 15mm spacers all around will that make it semi flush without any rubbing or fender work? tires will be 245/35-20f 285/30-20r
2011 g37x Coupe
Old 04-21-2012, 10:34 PM
GET_SOME
GET_SOME's Avatar
if you want to run those size spacers in the rear you will have to get extended studs because that offset rear doesnt have the stud pockets
Old 04-21-2012, 10:35 PM
timfactor
timfactor's Avatar
I run +32/+35 lowered on coils no spacers. Perfect. Check the vossen pic thread for pics
Old 04-21-2012, 10:37 PM
Diego@Vossen
Diego@Vossen's Avatar
No need for spacers for the sedan the 32/45 CV3s sit plenty flush and will be perfect with the tires you want to run. Here is G37X AWD with 32/45 and 245/285s.
click photo to view full gallery.
Same offsets are shown here 32/45.
Old 04-21-2012, 11:35 PM
Diego@Vossen
Sorry I just realized you have a new coupe! 32/45 offsets still look very good on the coupe I don't think they are anywhere near tucked. When I had 32/45 w 255/305 I loved it.
Here is 32/42 w 245/35/20 and 285/30/20.
Old 04-21-2012, 11:37 PM
Diego@Vossen
You can also avoid running spacers up front and grab the +20 and for rear grab the +45 and run your 285/30/20 and add a 5MM spacer. Or you can mount in new studs out back with a 15MM spacer amd sit at +30 which would sit very flush, but you will need to possibly trim rear bracket going +30 to avoid rubbing.
Old 04-21-2012, 11:43 PM
P Casey
P Casey's Avatar
20 25 with 245-30 and 265-30 toyo is a great.
Old 04-22-2012, 12:31 AM
xsonnixx
xsonnixx's Avatar
thats a great idea for +20 up front has any1 done this yet +20 front and +45rear? so +5mm spacer rear i wouldnt need to mount new studs? is that the minimum spacer without mounting new studs?
Old 04-22-2012, 12:34 AM
Diego@Vossen
Yup seen it in person and looks so awesome I will get you the pics hang tight
Old 04-22-2012, 12:40 AM
Diego@Vossen
Here you go, CV3s 20/45 with 245/35 and 275/30 but if you go 5mm spacer out back with 285/30 it would sit nice. Paul is slammed on KwV3s but with your Eibachs it woul sit nice as hell with the thick tires out back.
5MM Spacer will just slap on with no stud replacement required.
Old 04-22-2012, 12:43 AM
xsonnixx
xsonnixx's Avatar
isn't this half an inch different in the diameter wouldn't that be a problem with awd?
Old 04-22-2012, 12:44 AM
xsonnixx
xsonnixx's Avatar
omg those look so good !
Old 04-22-2012, 12:45 AM
Diego@Vossen
With AWD you need to stay within 3% rolling Diameter. 245/35/20 and 275/30/20 or 285/30/20.
Old 04-22-2012, 12:48 AM
xsonnixx
xsonnixx's Avatar
did he have to do any fender work?
Old 04-22-2012, 12:57 AM
Diego@Vossen
No fender work done at all, really not necessary with this offset.
Quick Reply: vossen cv3 help
