Biggest spacers without extended lugs??
Hey guys, i tried searching but didnt have much luck..
I wanted to get 5mm spacers for the front wheels, but am not sure if its safe without extended lugs. Anyone have any experience?
Would i be much better off with going with like 3mm?
Or i shouldnt get any spacers without extended lugs?
Any feedback is appreciated.
Thanks!
-IgS
Thanks!
-IgS
What are you trying to do? 3mm spacers will make no noticeable difference in appearance, they might help clearance issues. If all you want are spacers, get the ones that bolt to the hub like the H&R DRM spacers do. Then you bolt the wheels to the spacers. This is better than using longer studs for spacers thicker than 10mm and you don't have to change out the studs.
I might just go with the 3mm, they are $20 on ebay and are specific to the 5x114.3 pattern (not those crappy generic fit-all spacers) so the wheel still sits on the hub.
37
10-17-2020 11:12 AM
