09 G37x coupe wheel spacers?
What size of spacer would I need to make the stock 18 inch rim and tire look flush with the fender?Are spacers any problems on a awd car?
What are you lowered on?
I have a 2012 Infiniti G37xS Coupe. I recently installed rear H & R DRM spacers 20mm with my stock 19" 225s. The fronts are exactly the same size and diameter. My problem is that the garage that did the installation did not want to install my front 15mm DRS spacers reason being that they didn't want to be responsible for any resulting damage to the wheel bearings. I think that they are being overly concerned and that the real reason is that they never installed 15 DRS spacers in the front of a G37x before. Someone told me about plates on the front wheels of an X drive. I suspect that because these are DRS they would have had to remove the studs and this may have been the issue. Maybe they didn't have a tool to remove the studs and didn't want to bother?
Anyone have an issue with wheel spacers?
