not sure if a 13 will fit out back, i think that is equivalent to like 20x10-15 or something more in the negatives. and also if it clears the outer fender with out work it may hit the inner shock with the width
Fronts with fender pull maybe, but rears are going to poke a lot and inner clearance with the strut is probably going to be an issue. Don't think camber is an option because of this.
