I think I have a bad wheel bearing, anybody have experience with replacing them?
I've begun to hear a grinding noise come from my passenger side front wheel well, and it only happens when Im making slow left turns. It's not a rubbing noise, but more metallic.
I'm not the most mechanically inclined so I had a buddy look at it and he says it's probably my wheel bearing and it could be caused from my a combination of my slammed car, and some unknown object I struck on the freeway a year ago.
Anyone else replace a wheel bearing? How difficult is it? Where can I go to get one and how much should I expect to pay (parts and labor).
I *think* the bearing is pressed into the hub, then the hub+bearing unit bolts to the steering knuckle (at least thats what it looks like in the service manual). It doesnt indicate you need to press the hub+bearing combo out of the knuckle to remove it, there are 4 bolts holding the hub/bearing piece to the knuckle itself.
Replacing just the bearing can be kind of a PITA. You need a 10 ton press I think (I believe the spec is 6 tons but assume no press will be exactly what it says it is).
Might be better off seeing if you can find the hub+bearing already as one piece (i.e. bearing already pressed in) and just replacing that. You can check the top of this forum for a sticky link to the service manual....its a little more work for AWD than RWD but still fairly straight forward.
I paid the dealer to do this on my '01 i30 which seems like a similar (maybe even the same) setup. Cost me 400 or so for just the bearing to be replaced.......I had to have it done quickly so I sourced the bearing from Carquest for 50 bux. Luckily didnt need to replace the hub because no one locally had it and I was stranded 200 miles from home.
Again, a little more work if its AWD (since there is a driveshaft in the way) but the bearing/hub piece seems to be the same.
So, took it in to the dealership and sure enough the wheel hub/bearing assembly was damaged and needed to be replaced. So about $600 later i'll be picking up the car today.
![Banghead](https://www.myg37.com/forums/images/smilies/banghead.gif)
![NOOO](https://www.myg37.com/forums/images/smilies/no.gif)
petemo94 (11-29-2021)
I replaced my front left one on my X and it wasnt too difficult if you have mechanical experience. Just lift it off the ground and get to it. It maybe took me about 30-45 minutes but that was with air tools and a nice lift. It should be even easier if you have a rwd because you dont have to worry about the front axles. If you have any questions feel free to message me I have replaced several wheel bearing/hub assemblies on numerous vehicles.
I have a 2010 G37xS, 60k mi. My front passenger bearing went bad and I just went through the repair.
I am fairly mechanically inclined and I would say that this repair for the average person wasn't quite as easy for me as it was stated here. The big reason for me, rust. The rotor was rusted onto the hub like you wouldn't believe, took a piece of steel and 2x4 and two clamps to pop it off, I've never had that problem with any car I've owned before. I don't think it was unique to this car but just bad luck. Then the hub/bearing is press fit into the steering knuckle and it was too rusted in. I had to use the steering column as a hydraulic press and a hammer to work it out.
The entire repair took me 4 hours. Would have taken 1 if not for all the dang rust and knowing that the hub wouldn't come right out. So this is just a heads up for anyone attempting this. Have clamps, a rust solvent/pb blaster and some blocks on hand.
Spray the rusted areas liberally with penetrating lubricant (I prefer Kroil), whack the hell out of it several times with a dead blow hammer (not a metal hammer!), then put the puller on and go to town. A long handled breaker bar works best because you have more leverage. You can search YouTube for rotor puller to see how it's used.
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
Cr0tchf4i
08-19-2015 03:52 PM
drkashifa
General Tech Questions
08-15-2015 01:27 AM
