g37x in the snow (Kuhmo ecsta 4x)
I live in MN, and we had our first snow fall. There was between 2-3 inches of snow accumulation. I must say that the car does very well in the snow. It was a complete blast to drive. One thing, it did take a little getting used to when turning. You can get the *** end out if you are not careful. The stability control does kick in, but the car already has the back out.
For those that are looking at the Kuhmo ecsta 4X tires, I would recommend them. I purchased a set of 4 size 225/55/17 from a local Capital tire. I got them out the door including tax for $549. I also got a $50 mail in rebate as long as the tires are purchased before December. The tires performed very nice in the snow, better than I expected considering they are an Ultra high performance all season tire. I will give another update as the winter continues and the snow falls like crazy.
Thanks for the info!
I am currently looking for UHP all season and have nailed down my choice to General gmax as-03 and Ecsta 4x. Both have great reviews so far and you can't beat the price. However I didn't see too many comments on snow performance since both tires are very new to the market. I am in socal but I do go up to the mountains alot during winter for snowboarding. So snow performance is somewhat important to me also.
Pls keep us updated on how they do on deeper snow. Thanks!
Hey FootLong, did you also consider the Continental ExtremeContact DWS (in 245/50-17 size) or the Yohohama AVID ENVigor? Just wondering what steered you to the Kumho.
I too have narrowed it down to the General G-MAX AS-03 and Kumho Ecsta 4X but only because TireRack reviews seemed to favor them performance-wise in reviews. Price is better, too, but the mileage rating on the tires mentioned above is better.
I basically went with the oem tire size so the continental dws didn't work because they do not make a 225/55/17. I did look the yokos, but they were quoted $200 more then the kuhmo tires (counting the rebate. When I buy tires I always do a ton of research. I called tirerack 3 times and 3 different reps recommended the kuhmos in this price segment. I don't know if there is an incentive to push the tire? Any ways, I was set in the gernerals, but was talked into the kuhmos. Every tirerack rep and local tires shops said they were better overAll, and that the way the tread pattern was that they would be way more promising in the snow. From what I can see they were correct. But then again, it was only 2-3 inches. Mother nature, bring on that snow!
Just put in my order for a set of Ecsta 4x. Total with shipping came out to be $654 - $50 rebate, so about $600. This is for the stock 18 size.
I have also looked at DWS. For all seasons, that tire is the champ when it comes to snow traction. I didn't go for them since they are always back ordered on tirerack, and they have very soft sidewall according to the reviews.
Antirice, I think you will be very pleased with them....especially in the dry and wet surfaces. These tires do need about 250 miles of wear/break-in period to become the most effective. It makes a huge difference to wear the mold cure off
Yeah, in Dallas we don't get that much snow, but we do get an inch or two every couple years. More in the last few years... and I do travel north sometime, never want to be in show without all-seasons.
I think I'll go with the Kumho but in the 245/50-17 size. It's very close to the stock diameter (like .3 MPH off at 60 MPH) but 8/10ths of an inch wider. Only a few dollars more in cost, too.
So there really isn't an issue with putting on 245\50\17 on the stock rims of the sedan besides the tiny difference in MPH? Is there anyone here who is actually running on that size because I would get use those just for the improvement in handling alone and the bonus of looking better on the car.
I've had Discount Tire in Dallas tell me it's fine to run 245/50-17's on the 17" G37, and TireRack has as well.
Check out this site - you can compare how tires will spec out on the same rim.
http://www.rimsntires.com/specs.jsp
I have read this a couple of times here, "car does well in the snow" followed with "be careful or the back end will come around on you". I can't see how the car can be that great in the snow when if you take a corner slightly to fast you might go into a spin. I have a 37x running aggressive snows (blizzak ws-70s) and even with the AWD, traction control etc. our FWD Toyota Sienna with WS-60s blows the Infiniti away for winter driving confidence.
