when to do the tire rotation?
IMO every 3-5k if you are running some serious camber.. or every 8k or so for just a regular avg driver.
This is pretty subjective to your suspension setting and your specific needs.
Every other oil change would be fine. If you do a 10,000 miles oil change, then do it every change just to be on the safe side.
I have a 6mt so I have a staggered set up. I don't rotate my tires. I guess I could go left side to right side, but eh. Most of the benefit of doing rotations is going front to back.
The OP has an X. All four tires are the same size, likely directional and can only be rotated front to back. No crossing unless they are unmounted.
I rotated mine whenever they got close to 1/8" difference between front and rears. I don't base my rotation on oil change intervals. One has nothing to do with the other. Oil is changed at regular intervals and tires wear depending on driving. I have the convenience of being able to do it in my own garage but that is irrelevant.
I use a tire thread depth gauge and measure the depth at the outside,inside and middle of each tire.
When I bought the G, I received 2 free oil changes and 1 free tire rotation. Now I do my own maintenance.
I had about 9,000 miles since the dealer did the free tire rotation when I last did an oil change at 15,000 miles.
When I checked the depth of the thread, at that time, all the tires were wearing evenly, so I figured I'd leave well enough alone.
Tom
Tom
infiniti g37, your signature indicates you do not have an s model so your 4 wheels, if oem, should also be the same size. Unless you have a journey with s package
the op has an x. All four tires are the same size, likely directional and can only be rotated front to back. No crossing unless they are unmounted.
the rear ones r 245 / 45 / r18
G37 sedans in North America have the same size wheels (all 4) unless the car is the G37S or is a G37 Journey with the Sport Package option added.
All others have 17x7.5 or 18x7.5, front and rear wheels.
