G37s Rims Fitment
G37s Rims Fitment
hey guys I'm trying to buy some rims for my g37s and idk what rims fit
can this Fitment work?
Size: 2 Front Rims are 20X9.0 +15 offset with over 3" Lip
Size: 2 Rear Rims are 20x11 +15 offset with a HUGE 5" Lip!
dam ShyAznB8oi your good ya thats what I'm looking at I'm all stock rite now i was thinking to go with the Eibach i had i on my 07 g35 sedan and i was happy with it.
how do i do the stretch?
Those tires sizes are too big for a coupe. Ill guarentee that. I had a 255/35/20 on my 10.5 +25 and I barely cleared the fender on -4 camber. You should run a 245/35 imo. That front will work fine with either a 225/35 or a 235/30 But a 20x11 +15 rear is the same as a 20x10.5 +9 rear. You will probably need either a fender flare or a fender roll to make it work without some crazy camber. And remember on springs you will bounce and might mess up your fenders cause you cant controll dampening. I say just do your research before jumping into it. Theres another member here who has a 20x11 rear, I forgot his username. Ill see if I can find his specs.
But were now talking about 20x11's though.. 245/35 would be nice or even 235/35 lol.
Really doggy? lol. I was running -3 camber +10 10.5 wheel with 255/35 and it was no problem. No major dinks or damage on the fender from driving about 2k miles. that was on the s-techs also
You sure those are the right sizes? lol Im on s techs and running a +25 rear and it just barely clears the fender when I tuck. I just got an alignment done and it said im at -3.8 and -3.9 If I run a 5mm spacer which will make it a +20 Im positive itll bang the fender. A buddy of mine ran a +15 with -3.5 camber and banged fender too. What wheel size were you on?
CV1 10.5 +15
I put an Ichiba 5mm spacer, becomes +10 right?
255/35/20 V12 hankook tires. Cambered at -3.
Okay, not I'm not sure at this point typing... It's probably +25 or +15 offset for the 10.5, will check on the wheel later.
