Wheel setup question...
09-19-2011, 01:37 PM
I am on a stock spring. Going to lower on eibach springs later.
But will these fit my 2008 G37s coupe well or the offset is off for G37?
It's from a G35 coupe...
20" Volk GT-7's
Front - 20x9.5 +22 Offset 245/30/20 Toyo Proxy
Rear - 20x10.5 +24 Offset 275/35/20 Toyo Proxy
Thank you!
Reason: added pic
09-19-2011, 01:53 PM
It'll be what I consider slightly aggressive. But most of the slammed crowd will tell you it's perfect.
Should look great. What color GT-7? I love those wheels!
09-19-2011, 02:21 PM
Quote:
I'm not slammed, but I think those offsets are close to perfect. It just may be an ideal set-up for our car.
I am running the same widths and (+22) all around. I have always said that a tiny bit more conservative in the back would have me content.
09-19-2011, 02:33 PM
Front would be perfect. Rear just run a little bit of camber in the back you will be fine. No need to stretch your tires.
09-19-2011, 03:05 PM
Offsets are fine. The rear tire isn't though, a 275/35 is a truck tire!
09-19-2011, 03:35 PM
front is fine but rears u will rub! stretch tires or run camber..
09-19-2011, 03:44 PM
The toyo's has a stretched sidewall already. I believe he can get away with it.
@doggy, why is a 275-35 a truck tire? Do You even know what a real truck look like?
09-19-2011, 03:48 PM
Doggy
My G is 4x4 status then...
But, yeah, the OP may need to address the tire sizes.
245/35 front and 275/30 rear would work.
09-19-2011, 03:56 PM
Weiboy718
okay... the he definitely need to run 275/30 with those offsets.
275/35 = rub for sure
09-19-2011, 04:46 PM
Weiboy718
Thought truck tires look like this...
09-19-2011, 04:50 PM
Just realized you have 20's, you can go 255/35/20 and 285/30/20
No need to stretch. In the front you shall be perfectly fine. Rear -2.5 camber and trim the bracket and all rubbing problems go away
09-19-2011, 07:27 PM
Kevalteam
20" Volk GT-7's
Thank you!
Maybe its me, but those tire sizes seems backwards! Its usually:
245/35/20 -vs- 245/30/20
275/30/20 -vs- 275/35/20
Double check and make sure.....if its 35 up front and 30 in the rear, your golden
09-19-2011, 07:35 PM
D_S_CUSTOMZ
You are correct.
09-19-2011, 09:48 PM
GraphiteG37S
my tractor still has some pretty decent thread! who want's to get run over? call me haha
09-20-2011, 01:40 AM
WPPJR30
Yeah... cause I rub a little in the rear with a 285.30 Falken on a 20 x 10.5 +32 w/ -1.8 camber...
Let me drive your truck Wei.
