Help rubbing?
rubbing?
Ok guys im a noob here just got my G37 coupe. Im trying to find out exactly what fits perfectly for our cars without stretching tires. Currently im running 20x10.5 rear +35 and 20x9 front +35 Tires are 275/35/20 and 245/40/20. Im scared of going to the smaller profile tires due to so many potholes here in Cali. i already bent one rim when i had 19's using a 245/35/19 so i stuck with the 245/40/19 size.
Ok here is what i wanna do and let me know if its safe... 285/30/20 and 255/35/20 would i rub? will i risk bending/cracking a wheel. ? Note im lowered on Eibach pro kit.
I only experience rubbing of some sort when i carry 2- 200lbs people in back. other than that no rubbing. but i dont know what im rubbing on it doesnt seem like its the fender otherwise i would have like cutting on my tires. Please let me know your thoughts! Thanks
![Big Grin](https://www.myg37.com/forums/images/smilies/biggrin.gif)
You're probably rubbing on the fender liner, all you gotta do is just trim it. I'm running 20x9.5 +35 and 20x10.5 +37 with 245/35/20 and 275/30/20 tires. Many people run this setup and shouldn't be rubbing at all with the fender liner trimmed. And yes you'll be fine with the tire sizes I listed, you shouldn't be bending any rims at all unless you're going over potholes full speed. I live in CA and I've driven over some pretty crap roads with these tires for years and I have had no issues.
I am lower than Eibachs and only rub on really steep driveways or very hard bumps. You should have no problems with the offsets that you described in your post.
I run those exact same tires sizes on my wheels which are 9.5 +25 and 10.5 +32 ... What brand tires are you thinking of getting?
So how is the ride quality and are they safe? have you hit any potholes hard? As for the brand of tires i kinda wanna be a guinea pig and try the Federal Evo595 in 285/30/20 and 255/35/20 if not then i might just go with the Hankook Ventus V12's. What tires do you run. i know some tires have thicker or wider sidewalls right?
I only experience rubbing of some sort when i carry 2- 200lbs people in back. other than that no rubbing. but i dont know what im rubbing on it doesnt seem like its the fender otherwise i would have like cutting on my tires. Please let me know your thoughts! Thanks![Big Grin](https://www.myg37.com/forums/images/smilies/biggrin.gif)
First, how did you get 2-200lbs people in the back seat of the G37 COUPE? lol
![thewave](https://www.myg37.com/forums/images/smilies/th_wave.gif)
I actually wouldn't suggest going with the 255/35 and 285/30 on 19's because your overall diameter will be much smaller. Your speed calibration will be off and you will have a better chance of damaging the wheels.
Like emyrl posted, triming your fender liner should do the trick
h
