Vossen tire/offset question... CV3s on way! confused ..
Old 08-20-2011, 04:19 PM
NOLA_G
NOLA_G's Avatar
I got them chrome plated! ................... Joking I got graphite
Old 08-20-2011, 04:26 PM
P Casey
P Casey's Avatar
nice, Looking forward to seeing it
Old 08-20-2011, 08:16 PM
OB G
OB G's Avatar
Why have you decided to ask these questions now after you've already ordered them. Should've done some research before investing so much. I'm on a conservative Eibach drop which is why I decided to go with the 32/42 offset. If you want custom offsets you have to pay alot more $$$ and be prepared to wait a while too.
Old 08-20-2011, 08:48 PM
aexis
aexis's Avatar
Some useful OEM stock info size/offsets for the '11 G
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Non-sport
Front & Rear 18x8 +43mm offset
Commonly used after-market offsets:
Front width: 8.5" +30-35mm offset Rear width: 9.5" +30-35mm offset
Old 08-20-2011, 08:58 PM
NOLA_G
NOLA_G's Avatar
My drop isn't conservative... Post pics of yours. I wasn't aware of the extra cost ... Can someone tell me the prices difference???? How is it custom if its offered ? It really doesn't matter .. I know the look I want and if I don't get the 20/25 ... I'll be selling them in a week. I'm spending the money so I want exactly what I want.... As far as the whole why didn't u ask these questions before coulda woulda shoulda... I'm not going to answer that cause it doesn't really matter unless you have a time machine. I do want to say thanks again to everyone that posted on the thread everyone was cool and helpful as usual...
Old 08-20-2011, 09:08 PM
Frankyg37s
Frankyg37s's Avatar
he dint know about offsets hows is he supposed to ask about it,yes he should of done some research!!**** happens
,but yea i have 32/42 and its PERFECT for ME with eibach springs if youre LOWER than for sure get 20/25 more agressive but too much for practicality
Old 08-20-2011, 09:12 PM
NOLA_G
NOLA_G's Avatar
Franky - pics please? Yup it happens ... Heh
Frankyg37s
Frankyg37s's Avatar
and nola dont worry to much if there already shipped,,,as long as you dont touch them you can exchange !!!!!!!!!! worst case you pay shipping
Old 08-20-2011, 09:18 PM
Frankyg37s
Frankyg37s's Avatar
here ya go enjoy ][/URL]
Uploaded with ImageShack.us
Old 08-20-2011, 09:21 PM
kszcze47
kszcze47's Avatar
Nice ride franky!
Old 08-20-2011, 09:26 PM
Frankyg37s
Frankyg37s's Avatar
Originally Posted by kszcze47
Nice ride franky!
thanks pics dont do the wheels justice tho. and im a ****ty photographer
Old 08-20-2011, 09:34 PM
P Casey
P Casey's Avatar
looking good man
Old 08-20-2011, 09:45 PM
NOLA_G
NOLA_G's Avatar
Yes looks awesome .... any info on extra cost of 20/25??
  #29
P Casey
P Casey's Avatar
Majority of the pics you will want to look at are posted on the Vossen post up thread. With your drop you have a couple options. I suggest you listen to Diego (VossenG37s) and go with a 20x9 front wheel with a +20 offset, your tire size with be 235/35 and for the rear go with 20x10.5 with a +25 offset, your tire size with be a 265/30. These are somewhat aggressive offsets. They will be more flush to the fender than the +32 and +42 offsets. The +20 and +25 offsets you want will most likely require you to move or shave your bumper bracket to prevent rubbing. This tire size has a small stretch, look at Vosseng37s, he has the same set up minus the s techs.
The more conservative offsets will be the +32 and +42 offsets where you will be able to run bigger tires such as 245/35 on the front and 285/30 or 275/30 on the rear. A lot of people go this route because it looks good and they dislike the stretch tires look as well as other reasons.
So for our G's Vossen just have these 2 combinations of offsets available. Now if you want to make offsets of your own then you need to contact them or someone who deals with them to start that process.
There are not too many options for you because of your drop on a spring and they cannot be adjusted therefore your will only have a few choice unless you want to push the limits and go a different direction. With that being said here are your options..
You should be running 20x9 front and 20x 10.5 rears.
+32 +42 offset tires sizes
245/35 f 275/30 r
245/35 f 285/30 r
245/30 f 275/30 r
+20 +25 offset tire sizes
235/30 f 255/30 r
245/30 f 275/30 r Falkens only
235/35 f 265/30 r
and Doggy’s tire size
Old 08-20-2011, 09:49 PM
  #30
Doggy
Doggy's Avatar
I'm 225/35 front and 245/35 rear.
Quick Reply: Vossen tire/offset question... CV3s on way! confused ..
