Will wheels from an Accord fit a G37x?
I'm hoping to upgrade to a G37x coupe next year, and am trying to figure out if it would be a reasonable plan to use the summer wheels from my Accord as winter wheels for a G37x coupe?
They are 18" Sport Edition. How do I determine if the bolt pattern is the same and if I would need some sort of spacer?
I'm guessing that if I got the sport package there might be interferance with the larger brakes. Does that sound correct, or would the sport package brakes fit (assuming the wheels would fit the car at all)
I'm pretty sure the bolt pattern on Honda Accords are the same as our Gs. You need to know the offset too. Take off one of the wheels and look inside. It'll say the bolt pattern and the offset of the wheel. That'll give you a better idea of whether or not they will fit. As far as BBK, it might fit but you'll probably need spacers. IMO 18s look small on our car. I'd stick with the stockies over those.
Thanks for the information! I'll have to remember to check the wheels for offset numbers the next time I have them off.
And yes, this would be for snow tires, so smaller is generally better.
Now I just hope I can convince the wife that a smaller car is a good idea...
