Need help putting Sevas rims on my G37s
Okay so I picked up these Sevas rims S-22 the front are 8.5 width with offset of 40, does anyone know what size hub centric spacers I will need to make them work on my G37s n if I would need ones for the back rims which are 10 width, the rims are 20"?
the center bore is 66.1mm so you would need your spacer to be 66.1mm to be hubcentric. 25 mm in front will be a nice somewhat aggressive stance. If the rears are a +40 offset also then a 15 or 20mm would work to go with the front.
Good luck with Sevas man. I've heard they are pretty weak.
Should ask if you're lowered?
Thank you for the size n yea I didn't know that about the Sevas, someone told me they were good n I got a great deal on a set of used ones with new tires. Just wondering online when I look up the spacers they go by mm n the spacers I has were 10mm n they weren't big enough any idea which size I would need or type of spacers would work best?
