20in on G37x
performance comes from wheel weight & tires not from running bigger wheelz.
bigger wheel looks good but you will have to watch for pot holes and swerve around all the time. it's a stress.
I am rolling on 20s Vossen CV-2s as a daily driver.
Couple of things to know
1) make sure the offset is correct. You need to talk to someone who SPECFICALLY knows this for your car. Vossens have a few offsets which are called "direct fit" for G37 where you dont need any spacers etc. You need to figure out the offsets of those wheels and see if they will fit with the G. If the offset is too weak (+), you can always add spacers to get it flush. However, if it's too agressive (-), you will have wheels stick out of your fenders and look like those VW or Audi peeps (actually i think it looks good on their cars, just not on a G).
2) ride quality. I think mine ride as good as stock. Then again I have pretty meaty tires (255 F, 285 R) so the rubber cushions the road. If you run really narrow profile tires like some people do for a more stretched look, then you will have a little harsher ride
3) potholes. little potholes=no problem. Big potholes=swerve like a ****! Bigger rims menas less rubber so a pothole is more likely to curb your rim. If you live in pothole county like Canada, it's gonna be a pain. Where I am is rural but roads are pretty decent and I dont have problems
4) performance. I will guarantee you the 20s will be heavier than the stock wheels. That and you will have heavier rubber too. Your 0-60 will suffer, but car should be just as quick when rolling. I posted a thread on this "Do Vossens Make you slow?" it has all the explanations
5) Looks. Hellz yeah 20s look better and its pretty much the biggest you can go on a G. Anything above that is just whack (my opinion : )
6) Handling. Lower profile tires result in less roll and better grip.
All aspects of this upgrade are relative to what you want. If looks and handling are less important than ride quality and concern about potholes, then stick with stockies. Personally I love the ride quality of my 20's. I avoid as many potholes as possible regardless of what I'm driving on. Because I live on a hill with lots of curvy roads to get on and off of, body roll is something that I minimize at all costs and my lower profile tires help with that. I also do quite a bit of long freeway trips and am never bothered by road noise, bumpy ride or the sense that my "big" wheels are slowing me down. The G is so quick that I think it would be very difficult to be able to tell the difference between a 17 and a 20. Maybe on a drag strip, but really?
Good luck with your decision!
IrishMike
09-16-2015 07:07 PM
