Does wheel size have to do with ride comfort?
I want to get 20" wheels for my 2011 g37 coupe but a friend told me I will lose ride comfort. I'm thinking of doing an eibach drop with it. So my question is will I sacrifice lots of comfort if I get 20's?
title should be does wheel size affect* ride comfort
You'll sacrifice some ride comfort. You will have a shorter, stiffer sidewall that won't absorb bumps and irregularities as well. Wider tires will tend to drift with ruts in the road more. And when you drop it on stiffer springs it will definitely not be as cushy but will gain a bit of handling capabilities. It's a trade off. How much comfort you lose is subjective. It's not too much for many of us, some would rather keep the stock ride that's a little sporty and pretty comfortable.
With lowering springs, your ride will usually stiffen up a bit. But I heard with Eibachs, your ride will be pretty much close to the stock sports suspension, just a tad bit stiffer. As far as 20" wheels, your tires will be "skinnier" so you won't have as much sidewall to cushion your ride. As Black Betty mentioned, it's a tradeoff and ride quality tolerance is totally subjective so only you will know. It will, however, decrease ride quality and comfort a bit.
Yes wheel size affects comfort in a big way even more so than switching oem springs to Eibach and if somebody tells you otherwise that may be because of road conditions. I'm in Canada where winter is hard on roads and truck weight limits are higher than in U.S, perfect combo for Bagdad roads. I did the switch you're thinking about (vossen cv1+Eibachs). I ran about 2 weeks on 20" before putting the Eibachs on and let me tell ya the car was completely unrecognisable. Handling much more precise and sensitive but comfort went down a lot. Eibachs didnt stiffen the ride that much. I dont regret a single minute doing these mods. I cant stop staring at my car and to see people picking up their jaws from the ground when they look at it is priceless. I'have a couple of storys coming off playing golf with people i dint know, when they saw the car in the parking lot mouhhaaa!!! Go for it!!!
