Help need a which-tires-will-fit calculator
Old 06-10-2011, 03:41 PM
rks
rks's Avatar
Need Cheap Tire Suggestions
I decided to get a staggered setup as follows:
245/40/19
275/35/19
This size gives me the closest OEM rolling size. I am looking at the Hankook Ventus V12 evo K110 as a great value/option. Is there a better budget conscious tire there. Are there cheaper places than TireRack?
Old Question:
I am getting ready to buy some Volk RE30 with the following specs:
19 X 9.0 Off. 38
19 X 10.0 Off. 35
I need tires. I don't want a stretched look. Is there a calculator that can tell me what size tires will fit?
2011 S Sedan dropped on Eibachs with a rear camber kit.
Old 06-10-2011, 07:28 PM
Gee37S
Gee37S's Avatar
for the front, anything from a 245 to a 275 fits that size rim. For the rear, anything from a 255 to a 295 should fit. If you don't want a stretched look, but a rather flush look, run a 265 and a 285 you want have any problems. Only issue would be rubbing. See what people with that size and offset are using and use the same thing
Old 06-11-2011, 10:34 PM
myk1013
myk1013's Avatar
For those specs... I'd go with 245/35 and 275/30.
If you want a mild stretch, 225/35 and 255/30
If you want aggressive fatty tires, 255/35 and 285/30 (I have these sizes on my 9.5" front and 10.5" rear wheels.
I doubt you'll have any rubbing issues. You have 19's and Eibachs.
Old 06-11-2011, 11:41 PM
rks
rks's Avatar
thanks guys.
Old 07-08-2011, 12:45 PM
rks
rks's Avatar
bump for new question
Old 07-08-2011, 01:27 PM
Kidcane
Florida G Club
Kidcane's Avatar
Home - Discount Tire Direct
Get quote from Tire Rack and these guys will usually beat it.
Old 07-08-2011, 02:00 PM
rks
rks's Avatar
Thanks, That's where I went for my winter wheels/tires so I may pay them another visit.
Old 07-08-2011, 02:08 PM
ANMVQ
ANMVQ's Avatar
WOW you have the same thread as me.. AHHA Getting Avant Garde M310 Mesh --Hyper Silver-19x8.5 +35 and a 19x9.5 +40 and 245/40/19 and 275/35/19 Hankook K110 , In week or so.. But at least I know someone else found that this staggered set up is good.
Old 07-08-2011, 02:30 PM
Neal@tirerack
MYG37.COM Platinum Sponsor
Neal@tirerack's Avatar
The 245/40-19 and 275/35-19 is a very popular plus size.
Old 07-08-2011, 03:02 PM
TinsleyC
TinsleyC's Avatar
This is an interesting tire / wheel comparison tool:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
It will show you a visual comparison of how plus sizes will look and how a slightly different tire will affect your speedometer at 60 MPH. Set one tire on the left view and a different one on the right. Set the wheel size the same for both sides for an accurate comparison.
Old 08-16-2011, 10:11 AM
Aggieav8r
Aggieav8r's Avatar
I'm wanting to go 305/20 R20 in the rear - Eibach, Vossen 10.5, +42
Anyone know if this will work? It LOOKS like it will be fine ... but, hoping someone can say for sure.
Old 09-29-2011, 09:22 PM
HoustonG37S
HoustonG37S's Avatar
I have had my G37s for less than 3 months and have had two side wall blowouts after hitting potholes. I bought the car with Hankook tires, which apparently are HORRIBLE. So instead of replacing this last blow out with another Hankook, I'm thinking of different tires, but also different sizes. Do you think that Bridgestone Potenza RE760 Sports would be a good match. And the size I'm looking at are 275/35/19 on OEM Sport wheels and 245/40/19.
1. Would they look good?
2. What is this going to do to the ride quality? (this is my daily driver so I like comfort)
Old 09-30-2011, 08:56 AM
TeRRoRiFiC35
TeRRoRiFiC35's Avatar
why would you bring back this old thread instead of pm'ing Neal?
Old 09-30-2011, 10:45 AM
HoustonG37S
to get other people's opinions as well, not just someone who works at a tire store..............that's why
Old 09-30-2011, 11:36 AM
Here's an opinion. Drive more carefully. It's not a defect in the tires. It's your driving. I drive Houston roads and streets on Hankook tires every day for the last 4 years in my G. I used to have the exact same sizes, now I have comparable sizes on 20" wheels. I've never had a blowout. I have lots of friends who drive G's as well here and no issues with their Hankook's either. Hankook are pretty decent tires.
I don't think it's the tires, I think it's your driving habits. If you simply cannot avoid driving through potholes, slow down. Also, make sure they're always properly inflated. That helps.
Quick Reply: Help need a which-tires-will-fit calculator
