Advan RS-D Hub Rings
Does anyone know what size hub rings I would need to use to reduce the vibration on the Advan's? I have looked around for the specs but I can't find a definitive answer.
![Dunno](https://www.myg37.com/forums/images/smilies/dunno.gif)
Any decent shop should have a bunch of different hubs hanging around. I believe the standard size for Nissan/Infiniti is 66.1MM.
Wow my iPad 2 is awesome then!!! I think I figured out my problem...the hub rings I have now are 66.1 to 73.1 from my Vossens, so that .1 mm can cause vibration so I've been told.
Yes that's true. But if your current HRs were 72.9mm but you actually needed 73mm I can see why it'll cause vibration because there's a .1mm gap in between the HR and the wheel hub. With the 73.1mm HRs you have now, its snugged, so it's pretty tight, not loose, leaving no room for movement = no vibration.
Hopefully the HRs are you solution, if not, start by rebalancing the wheels.
I hope you get this figured out, because I don't even have hub centric rings and I'm getting them like Thursday or Friday hopefully. I've already had my road-forced balanced and I still get vibrations.
Anyways, are all hub rings that purple color that weiboy posted?
