Help Best tires with low noise? 225 x 55 x 17 to 245 x 50 x 17
I'm looking forward to replacing the OE tires on my non-sport sedan (RSA's). I'm looking for a tire you'd rate best, that also has low road noise? I've been researching here and the 'net... Conti DW maybe? But, I'd prefer the wider 245's and I don't think I can get summer DW tires in a 245 / 50 / 17. The Conti DWS all seasons I can, but, not sure if they would grip as well as the DW? I like Michelin's, not sure which ones might be best for what I'm looking for? Been a while since I bought new rubber.
Good performance is #1 I drive mountains and coastline on mostly dry roads, a lot.
Road noise #2, Given my hearing, road noise seems louder to me than most.
Size 245 if possible is #3 I'd like to go up a size from the stock 225's.
#4 is price.
Forum Members? Tirerack? Psychologists?
#4 is price.
I'm in the same boat, needing new rubber in a few months. I'm pretty well sold on the Continental ExtremeContact DWS. I live in Dallas which does get occasional snow/ice, and also want the 245/50-17.
Where do you live? If you expect any ice/snow I wouldn't do the summer DW tire. From what I read, the DWS is a good improvement over stock.
As for a Michelin, I have the Pilot Sport A/S Plus in my notes. Better dry traction & cornering than the DWS but not as good treadwear, or as good on water. For me, I figure the DWS is an improvement over what I have now (Goodyear Eagle RS-A) so it's all good. See this TireRack rating list:
Consumer Survey Results By Category
Edit: Actually, according to TireRack, there are only three tires in the 245 size:
http://www.tirerack.com/tires/survey...=y&sortValue=0
TinsleyC;
Thanks for the links. The DWS and Pilot Spot A/S Plus have been at the top of my list too. I live in Southern California, no snow. I drive mountain roads, but avoid them when ice or snow are likely. I like the wet grip of both tires and I don't see A/S as a disadvantage as long as the trade-off isn't great. I've read some reports of the DWS's pulling as if alignment was off, but, the posts were during early DWS production. I've had Pilot Sports in the past and liked them, but, not the current A/S plus model.
Maybe someone in the forum will share more insights?
MYG37.COM Platinum Sponsor
If dry performance/handling is your #1, then I prob wouldn't look at an all season. Although good in dry they won't quite offer the level of handling like a summer tire will, but are quieter. However, if you want to go to a 245 there are no summer tires really to choose from. There is a much better selection of summer tires in the 225.
If 245's I'd go with the DWS or Sport AS+. The AS+ will offer more dry traction over the DWS as well as steering response.
If the stock 225's I'd go the Yoko S.Drive or Firestone Wide Oval Indy 500.
Installed few days ago 245/40/19 front and 275/35/19 rear on oem mags.
Sold my almost new Re050a tires because they where to loud and harsh on our beautiful quebec roads.
Bought Ventus V12's. Less then 10 miles with them so no real review yet.
They are a bit less noisy(dont forget i also went up is size) but certainly more comfortable. Handling is as good as the 225/245 re050 potenza.
They are also cheap
They are also cheap
Really isn't, but you can get a good idea of how extreme you can end up going by the tire's class. However, I tell people who want a little bit of everything out of the tire, not one extreme or the other, to stick with an ultra high performance class. For summer tires, ultra high performance summer.... all season, ultra high performance (sometimes high performance depending on what's available) all season. Tires in those classes offer the best mix of daily drivability, moderate a/s traction (in the a/s class obviously), wear, ride, noise, dry/wet handling, etc.
