Got a deal for Michelin tires , my question is would they fit ? currently i am running 245/40/19 front & 275/35/19 rear (which i feel they are big) all wheels are 9" .
Car dropped.
Im a sedan so not sure how much this will help but yes they should fit. I'm on 8.5" front and 10" rears and runnin 235/35/19 and 255/35/19. I think your offset will come into play as well in determining if they'll fit. Good luck
Those tires will certainly fit on those wheels. The 235 will be a little stretched, but nothing too extreme. How are you lowered - coilovers or springs?
Tanabe sustec coilovers , if little stretched no worries right? The other reason for changing the current tires is the look , they looks huge .
If you think the current tires are huge then these would be perfect for you, might want to adjust the height a tad lower to close the wheel gap and it'll look great.
Sure I will do that , but tires wear too fast these days
