Wheel lock questions.
Old 03-29-2011 | 09:37 PM
  #31
Brooklynstar23's Avatar
Brooklynstar23
Originally Posted by Mike
If you put 1.5 threaded lugs on your car, you might want to check for damage. Usually you encounter some decent resistance after a few turns or two... unless you impacted the lugs on.
great i hope i didnt screw up my new car...ugh....i dont have the wheel locks from infiniti in the mail yet...there was a slight resistance but i put those on pretty tight..so yeah im basically screwed.
Old 03-29-2011 | 09:58 PM
  #32
Brooklynstar23
Update
Well i just went out and checked and sure enough the threading is screwed up...i put the stock lugs back on with some difficulty...the accords wheel locks came off relativly easy after a turn or two...
so now that im a complete moron what can i expect from all this? will my ride never be the same? could i get charged for this when it returns to infiniti after 36 months? are my wheels going to fall off?
please help
Old 03-29-2011 | 10:02 PM
  #33
Mike's Avatar
Mike
Get all of the studs replaced by a local shop. It's relatively inexpensive, so don't stress it
Old 03-29-2011 | 10:03 PM
  #34
Brooklynstar23
excuse my ignorance but what does that mean? lol
Old 03-29-2011 | 10:10 PM
  #35
breftayka's Avatar
breftayka
The studs are what the wheels go onto and then the lug nut fastens onto. What you screwed up on. You can take it to any mechanic and they should be able to replace them pretty quickly and for around $100-$200.
You probably have a friend who is handy and could do it for you pretty quickly. If you go to the dealer and have them do it it will be double-triple that cost.
Old 03-29-2011 | 10:11 PM
  #36
J2S2M's Avatar
J2S2M
He means to take it to any mechanic to have them replace the damaged factory studs that were originally on the car. These are the long studs that hold your wheels and where your lug nuts get screwed into.
Hope that helps.
*breftayka beat me to it.
Old 03-29-2011 | 10:14 PM
  #37
Brooklynstar23
Originally Posted by breftayka
The studs are what the wheels go onto and then the lug nut fastens onto. What you screwed up on. You can take it to any mechanic and they should be able to replace them pretty quickly and for around $100.
I get ya...I didnt know those could be replaced..how come he has to replace all of them? Only 1 on each wheel is whats screwed up?
...oh well..live and learn i guess...
Old 03-29-2011 | 10:17 PM
  #38
breftayka's Avatar
breftayka
I think Mike meant all of the damaged ones. If only four are bad get the four replaced. I'm not saying do it forever, but you can ride around with four lug nuts with no problem. I would get it replaced when you can though.
It's really easy to do this yourself by beating out the damaged stud with a hammer.
Old 03-29-2011 | 10:22 PM
  #39
Brooklynstar23
I dont trust my skills enough to do that to a 3 day old car lol
Thanks for all the feedback guys! I will take it to a local shop saturday morning and am going to put 15% tints on it later that day...
Old 03-29-2011 | 10:43 PM
  #40
Brooklynstar23
Nevermind...
I called a 24 hour AC Delco body shop nearby and they said the part would have to be ordered...but if its ordered before 7PM it can be aquired the same day. I will call them tomorrow and just go there when I get out of work at 5 PM....they said it would cost 50$-74$ dollars a wheel
I learned my lesson!
Old 03-29-2011 | 11:07 PM
  #41
breftayka's Avatar
breftayka
Nevermind...
You can pick up the stud anywhere man. Go to Autozone/O Reillys/Advance and get 4 studs and then take them to somewhere else. The parts will only be about $5 each.
Old 03-29-2011 | 11:19 PM
  #42
JMacsG37's Avatar
JMacsG37
i guess im the only one with the locks that your asking about. You can't put a socket/hammer to take these off. because the magnetic lock on the outside has a spring on the inside so it will just bounce back and it'll spin all day until the magnetic lock is opened. Then they have proprietary locks underneath the magnetic one.
That lock is not like the "infiniti oem locks" that every shop has a key to. Im glad i bought these, expensive yes but im happy with them. And i have a full set of formula locks so if they got these 4 off they'd still need another 16 sockets and a long time hammering to get my wheels
Old 03-30-2011 | 02:10 AM
  #43
Mike's Avatar
Mike
I should have been more clear. I meant all the damaged ones.
Old 03-30-2011 | 09:41 AM
  #44
Brooklynstar23
I called the shop and asked them if I came in with the studs how much would it be and they said it would be around the same 50-75$ they have to see how difficult this job is going to be to determine a final price....I called two more body shops and they told me the exact same price so I am just going to leave work early today and get it fixed.
Old 03-30-2011 | 03:48 PM
  #45
Alex57r's Avatar
Alex57r
Don't stress it. Its not so urgent that you gotta leave work and overpay. Find a shop you like that will do it at a price you are comfortabel paying. 4 lugs should hold for a little while. The first time I broke a stud was on my 1988 Chevy camaro when trying to change break pads on my own. Indeed that taught me a valuable lesson. if you can't even take a wheel off, don't try to do anything more complex... LOL Many many moons ago
