Damn!! GT-30's are hard to take apart!!!
Old 03-27-2011, 08:35 AM
JohnnysG
JohnnysG's Avatar
Originally Posted by christian655321
post pics of the powder coating, interested to see how it looks.
Old 03-27-2011, 08:47 AM
Kidcane
Florida G Club
Kidcane's Avatar
LOL so that was what the problem was this whole time. Glad you finally figured it out.
Old 03-27-2011, 08:50 AM
JohnnysG
JohnnysG's Avatar
^ Yea.. what a PITA .
Do you know what Loctite I should buy?
Old 03-27-2011, 09:07 AM
Djfarhan
Djfarhan's Avatar
in for pics!
Old 03-27-2011, 09:24 AM
4drScreamer
4drScreamer's Avatar
I suggest the blue stuff.
Loctite Threadlocker Blue 242 from Loctite Adhesives
Good luck with the re-assembly. Be careful with the torquing.
Old 03-27-2011, 09:31 AM
JohnnysG
JohnnysG's Avatar
Ok, do I put it ON the bolt when I'm putting it back together?
Old 03-27-2011, 09:43 AM
4drScreamer
Yes, on the bolt itself. Stuff works great, but your torque is the critical part. And check them regularly after you put them back on to make sure nothing comes loose. Wheels take a serious amount of abuse and constant vibration on road surfaces is not your friend. Drive it for a day and check them. Then a couple of days and check again. Then a month later. Check them every 3 months after that regularly.
Old 03-27-2011, 10:28 AM
JohnnysG
JohnnysG's Avatar
Just broke a screw.... great
Old 03-27-2011, 10:37 AM
Neal376
Neal376's Avatar
An impact driver and some heat would prolly work better
Old 03-27-2011, 11:01 AM
myk1013
myk1013's Avatar
fack! serious?! they break that easily?
what now?
I'm having second thoughts about tackling this project... may just end up painting the lip only.
Old 03-27-2011, 11:14 AM
JohnnysG
JohnnysG's Avatar
^ I wouldn't recommend you doing it by yourself.
....I'm so ******* pissed the **** off right now holy ****.
Old 03-27-2011, 11:33 AM
myk1013
myk1013's Avatar
sorry to hear that man... I can just imagine.
Ask TomieG what he used to improvise.... he mentioned he broke a bolt too.
I was going to do it with a friend, but probably not anymore.
Don't want to risk trashing a $4K set of wheels just for stupid a$$ bolts.
Good luck man.
Old 03-27-2011, 11:41 AM
JohnnysG
JohnnysG's Avatar
Well.... idk . I need to get a bolt. I would recommend just hand tightening them. Don't trust any torque wrenches unless it's digital.
I'm seriously so ******* pissed off right now, I think I'm taking the bus to school cause I'm done ****ing driving that POS mazda.
Old 03-27-2011, 11:46 AM
  #29
TomieG
TomieG's Avatar
Tomie - I'm going to torque it at around 20lb/ft I think, because alshubcaps (reputable on g35nyc.com) torqued them at 30lbs/ft. So, maybe 25 might even be OK .
At first i started out with 23lbs of torque...worked fine for 3 wheels.
But then on the last wheel i broke 2 bolts in a row & dropped it down to 13lbs...
But like i said, be careful to not break any because Mackin/Volk does not sell them separately.
Old 03-27-2011, 11:48 AM
  #30
JohnnysG
JohnnysG's Avatar
Do you have any advice where I can get them separately?
Quick Reply: Damn!! GT-30's are hard to take apart!!!
