Question on spacers
Question on spacers
So I picked up a set of ichiba 10mm spacers to make my front wheels spigot more flush. My question is on changing the studs, i did a search and keep finding info on the rear, for the fronts does the rotor and caliper have to be removed or is there a way the studs can be swapped without removing everything?
If they are V1 spacers, you NEED to take out everything. I actually did this this weekend with my dad installing H&R V1 15mm spacers. We got the little studs out without removing the rotor, but it wasn't worth it. Just remove everything. Plus, you'll never be able to get those long as$ studs in anyway, even if you try. Lol.
Btw, I experience vibrating. Idk if that helps or not. But from experience, Ichiba and H&R suck. I want some Project Kics
both are hub-centric with built-in studs...no vibrations here
Not a fan of the Project kicks design...but it was the only one i could find in 10mm that was hub-centric
