Help Advan RZ
Old 03-24-2011, 09:26 PM
WPPJR30
WPPJR30's Avatar
Originally Posted by kosstick
recommend me some tires!!!!!
Sizes or brand?
Old 03-24-2011, 09:28 PM
kosstick
kosstick's Avatar
Both I am thinking 235/35/19-275/30/19?? Also anyone know where I can get advan center caps?
Old 03-24-2011, 09:32 PM
WPPJR30
WPPJR30's Avatar
Are you slammed? What is your suspension set-up? You can go a bit wider on that front tire. Say, a 245, unless you're slammed and need to stretch. You could even go bigger than these sizes, too. 245/40/19 front, 275/35/19 rear if you wanted...
It all depends on the look you want.
Old 03-24-2011, 09:37 PM
kosstick
kosstick's Avatar
https://www.myg37.com/forums/private...en-cv-1-a.html tanabe coilovers here is my drop
its +25 offset all around so I can't really push a lot more than 275. I am pushing 265 with +25 offset on my cv-1 with a 10.5 wheel but with neg camber.
Old 03-24-2011, 09:50 PM
WPPJR30
WPPJR30's Avatar
Well, you have the adjustability of coilovers, so there's some room to play... But, it all comes down to personal preference. Some guys like the beefy/wide rear tire look, some like the stretched/slammed/HellaFlush look. I'm running a very similar set-up currently (I'm just a bit more aggressive). My current tire sizes are 275/35/19, 255/40/19. I am going to be swapping them out for something a little smaller in a couple months.
265/35/19 & 245/40/19
Everything taken into consideration (my desired stance, tire stretch, sidewall height, peace-of-mind, practicality...), that is my preference/what I would do. In the end, it's what you want...
I wish you luck...
Old 03-24-2011, 10:00 PM
kosstick
kosstick's Avatar
I wish you luck...
Are you more slammed than i am? I can always adjust so I believe I have wiggle room. I will prob go with the 245/40/19 275/35/19
Old 03-24-2011, 10:06 PM
WPPJR30
WPPJR30's Avatar
Right now I am not more slammed than you are... I would like to go a tiny bit lower than I am currently, but I can't because of the tire width. I would rub. However, my wheels are .5" wider than yours and my offsets are a bit more aggressive, as well.
Honestly, I think you will be very happy with those sizes you listed.
Old 03-24-2011, 10:10 PM
kosstick
kosstick's Avatar
245/40/19 275/35/19 these? I am a bit skeptical to go 40 in the front but then again i am going from 20" to 19"
Old 03-24-2011, 10:23 PM
WPPJR30
WPPJR30's Avatar
I understand your skepticism. That's why I said it all depends on what you are looking for. I went from a 20" wheel to a 19" wheel because I wanted a bigger sidewall, as the roads in New England are horrendous. I like to drive my car. I hate being worried about hitting a crack or bump in the road and wondering if I damaged a wheel. I don't want to ride on a rubber band. Hence, my 40 series front tires.
If you go a little wider, you can drop down to a 35 aspect ratio. However, you might have to do that in the rear, as well. Meaning, for instance, if you go 255/35 in the front - your sidewall gets a little smaller, but then you'll also probably want to go down in the rear to a 30 series sidewall.
Your car is pretty low. Member, TomieG, is slammed on 19's. I believe he is rolling on 235/35/19 and 255/35/19. Pretty stretched.
I don't know if I'm helping you or confusing you...
Old 03-25-2011, 01:40 PM
kosstick
kosstick's Avatar
Any Idea on brands tires??
Old 03-25-2011, 02:43 PM
J2S2M
J2S2M's Avatar
My recommendations are :
- Hankook V12 Evo's
- Yoko S.Drives
- Vredestein Ultrac Sessanta's
Old 03-25-2011, 09:41 PM
kosstick
kosstick's Avatar
- Hankook V12 Evo's
- Yoko S.Drives
I ended up with Nitto Invos what do you think?
Old 03-26-2011, 03:50 AM
J2S2M
J2S2M's Avatar
I haven't tried the Nitto Invo's yet. I've heard that they are decent. Let us know how they work out for ya.
Old 03-30-2011, 12:26 PM
  #29
msmching
msmching's Avatar
Lou @ amplified is running these isnt it? go to their site, and wait for the banner to change and you'll see it.
azndoc
03-23-2016 02:17 PM
rk325
10-13-2015 01:51 PM
RAVSPEC
Wheel & Tires
10-28-2011 11:41 PM
wakeboardr116
Picture Share G Coupe
47
09-19-2011 06:46 PM
HKSG37s
Picture Share G Sedan
37
01-28-2011 12:32 PM
Quick Reply: Help Advan RZ
