Buying aftermarket wheels, what tire sizes?
Old 02-26-2011 | 12:47 AM
fullvietFX's Avatar
fullvietFX
Hey everyone I drive a 2008 G35X with the sport package. I am buying 18 x 9 wheels and I was wondering what tire sizes should I get? I was thinking 245/45/18, but that seems too thin. I wanted something wider. I was thinking maybe 275/45/18 or is that too wide for the wheel?
Old 02-26-2011 | 01:04 AM
P Casey's Avatar
P Casey
why arent you getting 19's or 20's?
Old 02-26-2011 | 01:06 AM
fullvietFX's Avatar
fullvietFX
I had 20s on my G35 Coupe and the ride was terrible, I felt every bump. I was riding on 8.5x20/9.5x20 with 245/35/20F and 275/30/20R.
Old 02-26-2011 | 01:15 AM
da mayor's Avatar
da mayor
i have 18x8.5 on my G37x Coupe now and the ride is so much better than the OEM 18x8 wheels... plus i went 30mm offset instead of the OEM 43mm offsets
245/45/18 you can stretch it
Old 02-26-2011 | 02:08 AM
fullvietFX's Avatar
fullvietFX
Any pics of your wheels?
Old 02-26-2011 | 02:56 AM
B L U E S L A T E's Avatar
B L U E S L A T E
I've had 20x10.5 in the back with 295/25/20. What bump? hahaha
Old 02-26-2011 | 04:30 AM
fullvietFX's Avatar
fullvietFX
I might go for 19s if I can fit a 40-series tire one there.
Old 02-26-2011 | 11:07 AM
Loi's Avatar
Loi
^ 19's with 40 series would be perfect for a sedan.
Old 02-26-2011 | 01:20 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Does that above mean you had to stretch the 245/45/18 to fit on the 8.5"?
Old 02-26-2011 | 11:06 PM
fullvietFX's Avatar
fullvietFX
Would 19x8.5 with 255/40/19F and 19x9 275/40/19R be okay? I'm scared the 275/40 sidewall is going to looking too tall.
Old 02-26-2011 | 11:42 PM
soundmike's Avatar
soundmike
^ The difference is only 8mm (a little over a quarter of an inch), i don't think you'll notice it much. Although, 275/40 is a bit off for speedo reasons.
I run 255/40/19 all around on 8.5" wide wheels, no qualms whatsoever. Your choice of tires will also play a role in how "comfy" the ride becomes.
Old 02-27-2011 | 08:22 PM
fullvietFX's Avatar
fullvietFX
How did you calculate the sidewall? Maybe I should go with 255/40/19F and 295/35/19R. Thanks for the help by the way!
Old 03-01-2011 | 05:06 PM
soundmike's Avatar
soundmike
255/40 - sidewall height is 40% of 255mm, or about 102mm
275/40 - sidewall height is 40% of 275mm, or about 110mm
Old 03-04-2011 | 04:10 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Most common size is a 245/45-18. I don't see a 275 fitting up front either. A 245 will fit a 9" wheel so there's not much reason not to use it.
Old 03-05-2011 | 05:42 AM
fullvietFX's Avatar
fullvietFX
Will 255/40/19F and 295/35/19R rub if I don't drop the car?
