Help XXR 522 19X8.5 front 19X10 rear offset question
02-11-2011, 03:43 PM
I am looking into XXR 522 19" wheels. Because they are extreamly cheap and I guess some what reliable.
Would following work on my G37 S Coupe?
Front: 19X8.5 / 5-114.5 / +38 offset / CHROMIUM BLACK
Rear: 19X10 / 5-114.5 / +42 offset / CHROMIUM BLACK
If any of you are running the above offset have pictures will be greatly appreciated. Please advise.
Other options from XXR 522 would be
19X8.5 / +15 offset
19X10 / +20 offset
Which i am pretty sure will not work.
02-11-2011, 03:49 PM
use oem tires for 15/20 it might work
02-11-2011, 09:28 PM
could you use the 19x8.5 +38 on the front from the first set with a 10mm spacer and then the 19x10 +20 on the rear from the second set?
02-11-2011, 09:30 PM
Quote:
Originally Posted by
joo030879
Front: 19X8.5 / 5-114.5 / +38 offset / CHROMIUM BLACK plus 10mm spacer
19X8.5 / +15 offset
19X10 / +20 offset
this. incase i worded it weird
02-11-2011, 09:33 PM
19X8.5 / +15 offset
19X10 / +20 offset
these specs should work perfectly. my friend is running 20x9.5 with a +25 offset and that 19x8.5+15 is equivlant to that so i really think you'll be fine
02-12-2011, 12:46 AM
Those look real good, what color is your car? You can also run spacers to get your custom offset....
02-13-2011, 01:16 PM
joo030879
19X8.5 / +15 offset
19X10 / +20 offset
from my calculations... I would go with the 2nd set of offsets.... 1st set are a little too sunken in and would require major spacers.
Post pics when you get them man . . . . . thinkign fo getting these as my daily aftermarket wheels.
02-14-2011, 08:35 PM
I have these in gold 18*8.5 +38 Offset, Will these fit a X coupe, Sorry to ask my own question in your thread OP, But why start my own when you helped me,
02-14-2011, 11:17 PM
Well they look cool, but make sure it's not heavier than the OEM wheel cause that will create an issue!
02-15-2011, 10:02 AM
02-15-2011, 01:18 PM
jlac13
^ for sure, I agree
so what offsets are u getting?
02-19-2011, 01:17 PM
don't mean to steal your thread but...
would 275 tires in the rear fit the 19x10 +20 set up?
also 245 tires with 19x8.5 +15?
02-19-2011, 01:46 PM
I can almost certainly say a 275 wouldn't fit ^^^
02-19-2011, 02:38 PM
Gee37S
Oh ok thanks... So it should be okay with oem size tires?
e92ry
12-31-2015 08:02 PM
Intake
12-25-2015 09:38 PM
jakebeefsteak
08-14-2015 10:23 AM
GARRYDG07
08-11-2015 08:32 PM
Abramite
16
08-08-2015 08:35 AM
19x10 ,
19x85 ,
42 ,
522 ,
coments ,
ebay ,
g37 ,
gold ,
myg37 ,
offset ,
review ,
tl ,
wheel ,
xxr ,
xxr522
