Tire/Wheel size ? 18 vs 17
Here's a dumb question since I don't understand wheel/tire sizes.
So the size of the 18's on a G37 is:
225/50 18
My current vehicle (pont g6) has:
225/50 17
So how much more "low profile" are the 18's, compared to my current 17s? Is the difference just one inch 18 vs 17 lol
Basically, the only thing holding me back from the coupe are the 18s, and knowing full well, my *** is going to hit a pot hole, or several over the course of ownership.
225/50 18
225/50 17
Depends who you talk to. If you talk to a baby boomer, he will tell you that 60 series is low profile. 20 years ago a very popular "big rim low profile" size was 205-55-16. Nowadays 16's are like 14's in the 80's. 18's are now becoming standard and 50 series are definitely NOT low profile. At least not by today's standards.
The 50 is the "aspect ratio", and in this case 50% of 225 is the height of your tire sidewall. So, that's about 11 cm. The aspect ratio itself, be it 40 or 50 doesn't make your tire low profile. Tires which are 280/50 and 225/50 have the same aspect ratio, but the wall height is different. Again, there's no consensus on what exactly is low for a side wall height, but the 18s on the G are definitely not. I wouldn't worry much about it. Many people have the G37S, with 19" rims and even less side wall height compared to the 18" rims. I would be careful to avoid potholes regardless of what rim size I had!
Of course, but hitting pot holes is almost inevitable, and my current 17s have been pretty absorbent. The only wheel damage I've done was when I ran on it flat, because I'm a moron.
Your rim size isn't the issue. Both tires you mention are 225/50, which means they have the exact same sidewall height. The only difference is what's stuck inside those sidewalls (17s vs 18s).
I know nothing about this stuff. I have stock wheels on my '09 x. The roads in Cleveland are in horrible shape. Would a different size wheel or tire size look more aggressive, without causing me problems?
04G35NYC
07-19-2016 01:42 AM
