Help Need help with offsets on 19x10 and 19x11 wheels
What offsets would be flush to the fenders with 10" wide rims in the front and 11" wide rims in the rear?
thanks
thanks
Here's a quick excel sheet I made to help you out by comparing new setups with any desired setup you plan on achieving.
OffsetComparison.zip
I use OEM sport wheels (8.5" and 9") with 25mm spacers (+18 offset) front, and 20mm spacers (+25 offset) as my reference since they flush nicely with my Eibach Drop
Sam's calculator is good. This is also one of the better calculators around, especially since you get a visual difference between the wheel/tire sizes. Only problem is you can't calculate stretched tires using this one.
http://www.rimsntires.com/rt_specs.jsp
