I'm having serious traction issues. I like the stretched look, but I'm pretty sure that's a big part of the problem. Barely half throttle from a dead stop turning a corner and sideways I go. It's pretty annoying.
Any solutions? New tires are obvious, but recommendations would be nice. Cost not really an issue if that helps at all. Many thanks.
So, did you do an alignment after your drop and wheels? You can never tell by the naked eye how much it is cambered in.
Alignment was done after the drop. Never noticed any issues with the stock wheels and the drop without an alignment. The moment I put the wheels on, traction became an issue.
Did you go from 19's to 20's? If so, that might slightly affect your alignment and possibly throw off your toe.
Stretched tires are known to have traction issues, I had first hand experience with it also.
I would get another alignment just to be sure.
