Official Vossen G37 Wheel Thread! Post Up!
#1051
#1053
20x9 Hankook V12 225/35/20 0 Offset Fronts
20x10.5 hankook V12 255/35/20 +15 Offset Rears
D2 Racing Coilovers Slammed(must lower the fronts more, so it evens out with the rears)
Natural Front Camber -4.0
SPC Rear Camber Kit -3.0
#1057
Thanks! I just drive it lol, just gotta be careful with your surroundings. Our downtown SD is one of the worse place to drive this low.. I messed up my underneath engine cover.. It got caught on the rail road tracks , will be removing it today, and possibly lower the fronts more.
Thank You!
#1060
I said this in my thread but it's worth reposting, These guys have quality products, unbelievable customer service, and there real cool people, and i don't get a dime for saying this for people that doubt the sincerity of the post... If you guys decide to get there wheels be assured its a smart choice. It was great meeting bro
#1061
QUESTION ...I have CV3s w/ Eibach springs and camber. Once I hit about 65mph my whole cars starts shaking...steering wheel & seats....Does anyone else have this setup and this problem? I'm thinking it's either 1 of 4 things: #1. bad rim, #2. a dead tire, #3. springs can't support, #4. wheel balancing or alignment...
Before you advise, know that I've had these tires balanced about 5 times now to try to correct the problem. I had an alignment done after installing the springs...When I first installed the springs I still had my stock wheels and did not have the shaking problem...it only started after putting the vossens on, hence why I think it's either #1 or #2.
Thanks!
Thanks!
#1062
If you already checked balancing amd alignment and problem still continues I would say have shop check for a bad rim! If that is the case that you have a bad rim then we will proceed from there. Me among others have similar setups w way lower drops with Zero vibrations so could be your tires or possibly rim. Check the rims and we go from there, keep us updated through email at diego07z@yahoo.com or email Mike@Vossenwheels.com!
Do you recall who you purchased from?
#1063
Thanks for the quick response! ...Yes, I bought them from Rim Source in Baltimore. I will have a shop check the rims and tires separately to see which they think it is when I get a chance.
#1064
What offset did you run on the front and back? Also what tire size did you go with? I am thinking of the same wheels with an 1-1.5'' drop.
#1065
I am running 20x9 +32 245/35 in front and 20x10.5 285/30 in the rear on BC coils. SPC kit just came in yesterday planning on lowering another 1/2" in a few weeks...
