Would you like your rim poking out w small stretched tires or some wide meaty tires? I ran many set ups and I would strongly encourage you to go with the 32/42 with 255/305s or 245/285 or 255/295s depends what u r looking for, Or if you want a Stanced out Look go 20/25 235/255s but you will sacrifice tire life but damn it looks good! Vossen has something for everyone. First ask your self this, what kind of driving do you do and are you looking for practicality or just looks!
what does it mean to stretch tires? i would like something that looks good but will last long for the tires also. and something that doesn't rub. I'm a pretty aggressive driver, what do you think?
Mines lasted a long time. I used my CV1's close to two years n the tires still had 50% tire thread left, when I sold the wheels. So on that note, if you take Care your wheels n don't drive like a maniac stretched tires would last just as long as regular tires IMO
Concave totally looks better when the offsets are lower such as the +20 +25, it also makes the car look a lot wider. The 255 +32 and 305 +45 will obviously make the tires look wider but it does not look as concaved. If your going to go with a lip wheel get the +32 +45 255 305. If your going to go with a concave wheel I would get +20 +25 run 245/30 and 275/30 depending on your drop. You obviously will shave your bumper bracket which I didnt like the thought of at first but its no big deal......
So should i go with the +32/42
and run 255/305s?
will this cause any rub? (tein s tech springs)
haha, i dont wanna run into any problems.
You will not rub with the wide tires with the 32/45 offsets on CV2/3 the look is phenomenal . CV1 also offers the 32/42 which also looks great . I ran both and yes 20/25 looks more concave cause u can see the concave from the rear view more but you have to be willing to run stretched tires and shave your rear bracket which sounds worse then it is but its worth it! If this is your DD I will recommend the higher offsets and wide rubber over the stretch and poke. Just my .02 from experience
