Official Vossen G37 Wheel Thread! Post Up!
Old 01-30-2011 | 08:25 PM
  #46
BooSa37's Avatar
BooSa37
255 in the front u serious? U need 245 at front. 285 is fine in rear, but first are u dropped? Those offsets should be fine without spacers. Some member are running 38/42 without spacers
Old 01-30-2011 | 08:31 PM
  #47
Modme's Avatar
Modme
I'm dropped by about an inch.
Old 01-30-2011 | 08:36 PM
  #48
P Casey's Avatar
P Casey
i would run the same size tires as i have. 245/35 f 275 30 rear, i have a 32 offset in front.
Old 01-30-2011 | 08:42 PM
  #49
VossenG37S's Avatar
VossenG37S
W +38 u need a 6mm spacer at least to clear if i were u i would run a 15mm hubcentric spacer and sit at 23/42 that should look ok!!! Depending on drop though i doubt a 255/35 would clear! U will def want to raise it! Unles u go 245/35 u should be ok! Def front needs to be spaced out though. Don't run flat spacers u need at least a 6mm for clearance so i recommend a 15mm spacer w a 245/35 and don't slam so low on front.
Old 01-30-2011 | 08:45 PM
  #50
VossenG37S's Avatar
VossenG37S
CV1 +38 have caliper clearance issues , u need at least a 6mm spacer to clear or u gonna hit caliper! But then again u need Hubcentric to eliminate vibrating issues.
Old 01-30-2011 | 08:46 PM
  #51
Modme's Avatar
Modme
Thanks for the help guys. Would it be a problem running 245/35/20 with 285/30/20 in the back? According to the wheel calculator, at 60mph, the front would read 59.6 and rear would read 60.1mph. Would the 0.5mph difference trip the vdc/abs?
Old 01-30-2011 | 08:49 PM
  #52
VossenG37S's Avatar
VossenG37S
That set-up I's the proper size to run actually , that's what vossen recomends so u have proper speedometer readings. This I's the best most practical comfortable set-up.
Old 01-30-2011 | 08:53 PM
  #53
VossenG37S's Avatar
VossenG37S
Vossen also offers Akata 6mm spacers that u can run on Front to be at a +32 ! Look into that also if u want the 255/35 but on a 9.0 front def stick to 245/35z
Old 01-30-2011 | 09:00 PM
  #54
Modme's Avatar
Modme
Sounds good. I'll switch to 245s and slap on some 10mm spacers.
Do you think I can run any spacer in the back with 285s? Just dont want the rear to look too tucked in or uneven compared to the front.
Old 01-30-2011 | 09:04 PM
  #55
VossenG37S's Avatar
VossenG37S
U can run 10mm spacers but u need to install the extended studs because 10 won't let the stock studs fit the lugs! They not long enough and even if u get spacers w extended studs your stock studs will hit back of rim and will need stock studs to be shaved down .
Make sense? Hope this I's clear.
Old 01-30-2011 | 09:05 PM
  #56
VossenG37S's Avatar
VossenG37S
If i were u honestly for all the concerns! Just hit up Jav at Vossen up for some Akata 6mm spacers on front and rear and sit at 32/36 offsets! That will look good.
Old 01-30-2011 | 09:06 PM
  #57
Modme's Avatar
Modme
Yeah, I understand the spacers. Even if i got the 6mm ones, i would not feel comfortable without extending the studs. So i'm planning to get teh eibach pro 10mm with extended studs. I figured if i could install my own turboes, i can change out the studs.
Old 01-30-2011 | 09:08 PM
  #58
Modme's Avatar
Modme
I just wished i found out about the caliper clearance problem before i bought the 38 offsets.
Does everyone with 38 offset have problems with sport brakes? Did anyone not have the problem.
Old 01-30-2011 | 09:09 PM
  #59
VossenG37S's Avatar
VossenG37S
Then u set man! Def go 10 then that's gonna look sweet .
Old 01-30-2011 | 09:11 PM
  #60
VossenG37S's Avatar
VossenG37S
It was the first batch of CV1s that had this issue! Maby u can contact Vossen to see if they will swap out the front to a +32 ! they have 5 year workmanship warranty ! It's worth a shot .
