Official Vossen G37 Wheel Thread! Post Up!
#2266
That's the exact same set up I'm going for!! already have the wheels and waiting on my springs to come in. I was just wondering if you did any fender work and how much camber your running front and back. Do you ever rub?
#2267
This setup was a 20x9/20x10.5 +20/25 offsets with 235/30/20 & 255/30/20 Hankook V12s.
Rear bumper bracket and fender liner were trimmed.
Recommended for the G37 to avoid any modifications and/or stretched tires is our 20x9 +32/20x9 +45 offsets with 245/35/20 & 285/30/20s.
#2268
I got the same wheels for my G37 with the exact same tire specs and my H&R springs are coming in next week. I was just wondering how much camber are you running front and back? And if you done any fender work?
#2270
Infiniti T-Shirts now available.
http://www.vossenwheels.com/store/it...il.aspx?id=240
The following 3 users liked this post by Diego@Vossen:
#2273
Diego - Can you chime in with advice? I am going to by the new CVT's this week. I have a 2008 Coupe lowered on Tanabe Sustec Pro coil overs. I am also ordering the SPC front and rear camber kit.
What size rubber would you recommend? I would like a 275 width in the rear, if not a 285... THANKS!
bachelor (11-07-2013)
#2277
Asking about CV5
Hi, Diego,
I have a G37S convertible 6MT. I looking for a set of CV5.
9J for front and 10.5J for rear and 245/35/20 275/30/20 tires.My vert is lowering by H&R lower spring and use the stock brake. What is the best offset for front and rear CV5 ?20/25 or 32/45? Do I need to buy camber kit after the update? Will I have any problem? Where is the recommend dealer of VOSSEN in NYC area?
Thanks,
Martin.
Thanks,
Martin.
#2278
Hi, Diego,
Thanks,
Martin.
Thanks,
Martin.
Thank you for the interest. With a drop like H&R I would still recommend getting a camber kit to correct both front and rear. SPC makes a great product.
I actually have these 2 options currently available for you but if you are interested in a new set or different finish you can contact our dealer in your area.
We do recommend 32/45 for the best fit with the proper tires for your G.
https://www.myg37.com/forums/private...5-32-45-a.html
"Competition Wheel
631-580-2400
Pat@compwhl.com"
#2279
TPMS Help, will not fit with Vossen CV3 wheels???
Hello All, I am new to this forum and am looking for a little help here.
I have a '12 G37S and just purchased Vossen CV3's (5 spoke) wheels, the 19 X 8.5, 32 offset fronts and 19 x 10, 38 offset rears. The problem I am facing is that the stock TPMS will not fit on the front wheels. It is too long and hits the brake caliper. Does anyone know of a solution to this?
Diego, can you help???
I appreciate all you can do for me......
#2280
TheGanglyGoon (12-15-2013)
