Official Vossen G37 Wheel Thread! Post Up!
#1953
A few pages back I wondered if a 20x10.0 +25 might be possible on all corners but turns out the CV3 20x10.0 only comes in a +45 offset for 5x114.3 so +25 is not an option. Well I guess if you used 10mm spacers then you'd be at 20x10 +35 which could be a decent concave look, slightly less aggressive than the +25 combos here. I'm only suggesting this as we can't have our wheels stick out past the fenders.
I am not sure if concave of the 20x10.0 wheels is the same as the 20x10.5, I assume they would be.
A setup with F: 20x10.0 (+45) & R: 20x10.5 (+45) might be the closest "conservative" way to get a dual concave look? I think the issue will be this offset fouling on the front sports brakes though. From some searching I think you need approx +30 or lower to have something this concave fit. Well based on 20x10 sizes of other wheel types anyway. The outer face of the 20x10 (+45) rims should at about the same spot as the 20x9 (+32)'s. If the 20x9's are close to the brakes then then the 20x10 (+45) will have no chance without a spacer and then you should probably go with the +25 offset 10.5's anyway.
#1954
OK here's a sneak peek at my G. Just took a few pics with my iphone. More to come later. I have this thing with lime green, silver, and black. So I painted my inner hoops lime, just to be a little different. Hey Diego I found that bumper bracket you were talking about that needed cutting. You shaved it off completely right? I just trimmed mine but if you think it needs to come off completely Ill do it. Let me know what you think. Front bumper is going on as soon as the grill is painted. Laters
[/IMG]
Cv3's 20/10.5 with +25 All four. Falken 275/30/20
[/IMG]
#1957
[/IMG]
[/IMG]
#1959
I'm right there with you bro. I was thinking the same thing. Was even thinking of either polishing the faces of the spokes or even doing a chrome wrap on them. Seeing that I do wraps for a living. The ride height right now is 24 3/4. It still needs to be adjusted a bit higher 24 7/8.
Man that rear is looking low, looks so good though. What's your ride height set at? I'm not completely against the lime green inner barrel but I feel like the spokes should be a different color than the silver to really accentuate the black paint and let the lime pop more.
#1960
I'm a whopping 1/8th of a inch lower than Diego lol. Thanks for the like on the lime hoops. Got the idea from this sweet G32 vw on you tube. Although he painted everything orange except the spokes on his cv3's. he's from Germany and has a video on YouTube for Vossen. Check it out. That car is so low it's crazy. Waiting on my fog lights and painting the grill and the ill bumper goes on. Then it's photoshoot time!
#1964
Thanks brother. Its sweet to see this thing almost done. If I hadnt watch your videos I might not ever of done all this. Quick question. You still have all your inner fender lining right? Or did you have to trim any of it. Im thinking the camber will help once I get it aligned but for now its rubbing the felt inner well in the rear and a little in front. Your thoughts?
