Mounting and Balancing
I'm going to replace my tires. Do I need to pay extra for balancing the tires each time i mount new tires? And do i have to do an alignment as well?
Unless you want your car to shake over the speed of 55MPH you should every single time you mount a new tire have it balanced. Also go to a reputable shop that does this. In Miami 3 out of 4 shops can not get this right! No alignment is needed on your car when you add new tires. Only needed if you mess with the suspension.
Murkr
09-28-2015 10:45 AM
