Replacement Tires
Replacement Tires
My 2008 G37S is coming up on 40K miles and I need to start looking into replacement tires. I understand the stock tire sizes are as follows:
Front: 225/45/19
Rear: 245/40/19
I also understand that you can go with 245/40 in the front and 275/35 in the rear on the stock rims. I would like to go with the larger tires but I have more concerns on the rear because of the significantly larger width. Could this wider tire cause problems such as rubbing when you have passengers riding in the back seat?
Any inputs would be greatly appreciated.
Front: 225/45/19
Rear: 245/40/19
Just had an interesting conversation with the dealer where I bought the car. They are telling me that the 245 front and 275 rears are not recommended.
Does anyone have any recommendations for tire installers in the MD area?
Dealer is always going to be against changing anything from what is sent directly from the factory. My feeling is that stock these tires are stretched just a bit. Going bigger can always create problems, but I think those sizes have been proven time and time again and are fine.
