Vossen Experts/Addict Question! wheel offset/tire choice
Old 12-18-2010 | 01:40 AM
kkokko's Avatar
kkokko
Hi,
For the Coupe, how would the following offset/tire choice look with an eibach drop?
CV1
20
Fronts 20x9 235/30/20
25
Rears 20x10.5 265
I believe the ideal tire size is 245/275 for an eibach drop with 20/25 offsets. But what would a 235/265 look like ?
Old 12-18-2010 | 01:43 AM
G37Sam's Avatar
G37Sam
You're talking about a 1cm difference in tire width, shouldnt be so worrying
Old 12-18-2010 | 01:54 AM
kkokko's Avatar
kkokko
oh i didnt know it represented 1cm :s
Old 12-18-2010 | 04:18 AM
G37HKS's Avatar
G37HKS
buy offset 20+ for the front with 255
the rear with offset 45+ and wrap it with 305 and buy 5MM spacer for flush look..
Old 01-02-2011 | 11:51 AM
money042's Avatar
money042
it'll also vary from one tire company to the next. 265 from Kumho will look different than 265 from Nitto, etc.
btw, great choice in wheels!
Old 01-02-2011 | 12:27 PM
JoshLee89's Avatar
JoshLee89
kkokko
I am the person to ask. you lucky lol
I have S-tech drop
Camber kits
Wheel bracket shaved slightly (I first was going crazy "what going to cut part of my car? lol it's nothing.)
CV1 Matt Black F+20. F+25
235/35/20, 265/30/20 General exclaim UHP (or UPS? I forgot lo
Slight stretch on both front and rear. looks perfect. Never rubbed.
Rear wheel camber at -1.2. everything in spec
Old 01-02-2011 | 12:29 PM
JoshLee89's Avatar
JoshLee89
you should get 235 35 not 235 30. with 265 30 at the rear. Your front will seat too low with 235 30. Or at least Front will sit much lower than rear, wouldn't match
Old 01-02-2011 | 06:01 PM
kkokko's Avatar
kkokko
Wheels: CV1
F: 20x9 +20 R: 20x10.5 +25
Eibach Springs: F: 1.2in R: 0.8in
S-Tech Springs: F: 2.1in R: 1.9in
Hm... Diego recommended the following for eibach drop. on 20/25
245/35/20
275,30,20
What do you think? It looks like eibach the front will be lower compared to stech (lower in terms of difference between front n rear)
Old 01-02-2011 | 06:15 PM
kkokko's Avatar
kkokko
With such a non-aggressive drop would 082s look better than CV1 on OB g coupe?
Old 01-03-2011 | 01:29 AM
JoshLee89's Avatar
JoshLee89
I mean. aggressive drop would look better on the car than non-aggressive either way, both 082 or CV1 or any wheels
With Eibach Drop. I would shave my bracket, with 20 25 offsets 245/35/20 275/30/20 would be perfect. And It won't rub,
Im with S-tech, my next set up going to be 20 25, 245/35/20. 275/30/20. and I will be fine
For wheels finishes, it's your choice.
Old 01-03-2011 | 01:34 AM
JoshLee89's Avatar
JoshLee89
I would go 20 25, 245/35/20 275/30/20
Doggy's Avatar
Doggy
You should go 20 front and 15 rear with a 235 front and 255 rear
Old 01-03-2011 | 01:48 AM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
This is what I'm running
https://www.myg37.com/forums/picture...ssen-cv1s.html
Old 01-03-2011 | 02:33 AM
JoshLee89's Avatar
JoshLee89
you don't need to stretch 255 on the rear with eibach anyways.
Don't stretch if you dont have to.
Old 01-03-2011 | 02:40 AM
kkokko's Avatar
kkokko
Yea due to the roads I'm forced to do eibach drop so I'm looking for the best looking wheel and tire ofset to match the non aggressive drop.
