Tire Pressure
Regular air is 80% nitrogen. The specific heat capicity ratio of nitrogen is 1.404, the specific heat capicity ratio of air is 1.400. That the ratio of the amount of energy required to raise the temperature of the gas one degree. There's really no difference in temperature fluctuations between pure nitrogen and air.
Race cars and planes use nitrogen in their tires not for temperature reasons but for safety reasons. In case of a fire you don't want a compressed flammable gas nearby. Since nitrogen is inert if there's a tire and the tire does burst it will not feed the fire as air would since air contains oxygen.
COLOR="Red"]moisture in the air filled tires [/COLOR]has major impact on the tire pressure as temp changes. Nitrogen filled tires are lot more pressure stable as there's no moisture.
Nitrogen is good for all tires. Nitrogen filled tires provide safety, less pressure variance (contributed by moisture) and better life of the tire.
Costco/SAM's provide free service to it's members to fill the tires with nitrogen.
Yeah if you get it free why not. Paying for nitrogen is silly.
You can easily remove moisture from if there's a water filter on the compressor. Most gas stations won't have that but if you have a shop compressor at home it probably will.
Hi there, so far I'm enjoying my new g37s conv. here in miami. Question though, what's the right tire pressure for these 19" wheels? Also, is there a tire pressure monitoring on dash like with Nissan? I have touched all controls possible with no success. Thanks for your help.
2009 G37S Convertible, Premium/Nav/Sport, Liquid Platinum/Graphite
mmnjtwa
09-07-2015 03:27 PM
footballmania32
09-04-2015 04:06 PM
footballmania32
09-04-2015 03:17 PM
