Ateq tpm quickset reset tool
SoCal Driven
The ATEQ TPM QuickSet Reset Tool is a valuable tool to reset a vehicle's Tire Pressure Monitoring System (TPMS) when replacing sensors or swapping tire sets, for instance, from a summer Tire & Wheel Package to a winter package. Additionally, the tool's "swapping tires" function assists the user in tracking and recording the TPM sensor information after rotating tires. Perfect for the track, too!
Features:
Compatible with future applications (upgradable online)
Advanced stream decoding for faster signal recognition
OBDII plug-in extension cable
Easy, step-by-step instructions
Tire rotation tracking and recording
Save and restore old tire configuration
The PC software (included) provides easy, step-by-step instructions for reset without requiring a visit to your service center or dealership.
Basic Instructions for Use:
Load software and follow on screen instructions
Plug the QuickSet tool into the vehicle's on-board diagnostic port (OBDII port located under the dash above the pedals) to download the current sensor ID codes the vehicle is monitoring.
Connect the QuickSet tool to the PC and enter in the second set of sensor ID codes.
Using the "winter" and "summer" buttons on the QuickSet tool, you are now able to switch back and forth between two sets of wheels when you plug the QuickSet tool into the vehicle's OBDII port.
IMPORTANT: The QuickSet Reset Tool can only reset the TPMS on four vehicles. More than four vehicles cannot be added nor can vehicles be removed from the tool or its software. If five or more vehicles need to be reset, an additional QuickSet Reset Tool will need to be purchased.
Download complete user manual. (PDF)
Recommended PC System Configuration:
Operating System: Windows XP, Windows Vista, and Windows 7 (not compatible with Apple/Mac computers)
Processor: Pentium ≥ 333 MHz (or faster)
RAM: 512 MB (or above)
Hard Disk Space: ≥ 30 MB
USB Port: USB 2.0 (required)
I thought you did not sell this tool anymore???
FYI to others...if you have two sets of tires, one for 3 seasons and one for winter use, you absolutely cannot just switch tires back and forth and NOT have your TPMS light come on. It will come on unless the new sensors are registered to the ECM and relearned too....Nissan and other Asian vehicles are twice the PITA than American vehicles with the TPMS procedure.
