Vossen cv1 *** NIGHTMARE - Nevermind, I FREAKED OUT***
#123
Im at mass infiniti waiting for mr kenny to come down so I can cry to someone. The alignment guy didn't do **** today. Said I need to put 250 miles on it for set in. Car still making squishing sound when it bounces. Alignment is all out of wack. Ill post crazyzy numbers in a second.
#124
dude this supension is making stupid crazy squeaking noise!!! at some points sounds like its hitting the bump stops! i literally have no idea what the hell is going on now!
#125
also when i was getting off the pkwy ramp this morning on my way to the mechanic to check out the noises my rpm got stuck at like 4000 rpm's i know my tire sizes are perfect so i cant imagine what that was about!
#126
The noise you're hearing is the notorious clunking from the rear shock mount. My friend has the same issues and he learned to live with it. That's what you called you get what you paid for. Stop complaining already
#127
Wow! You're just running around whining about the same issue lol. You should've done your homework and got KW V3 instead.
OP has an X" model, so kw wont work for him.
OP
best thing to do is have the mechanic take out the rear coil and inspect everything.
#128
#130
just got back from the mechanic we reinstalled everything, greased and lubed everything, torqued everything to spec. and it still drives like garbage. alignment isnt done so im not factoring that in, but the noise issue is MY ISSUE!
#135
ill definitely come next time for sure...... been meaning to get to the meets and put some faces to the names. i just dont wanna drive the car the way it is..... like da mayor said im getting over to vinnyten first thing monday morning, were gonna check this nonsense out. i have a feeling i got rwd coils and thats gonna suck cause i cant get ahold of bc till nov 12th..... then i gotta wait to ship then i gotta wait to install.
