Best Replacement Tires for G37S?
#76
Guess the only way to truly know what you have is pull one front and rear off the car. The dimensions of the wheel will be cast into the backside. ET = offset and should say something like 19J8.5 or 8.5J19 etc representing the diameter/width.
#77
ok guys, HELP ME DECIDE:
oem size michelin pilot ss or
245/275 (larger) continental extreme dw (still less expensive then oem michelin)
I am an average driver on california roads, I like to take corners a bit fast, nothing else crazy. I have eibach sway/roll bar combo all else stock (and back ceramic brakes).
I dont want to lose speed off the line or screw with my suspension etc.
#78
Assuming you have a coupe:
225/45-19 O/A circumference = 84.736"
245/40-19 O/A circumference = 83.933"
245/40-19 O/A circumference = 83.932"
275/35-19 O/A circumference = 83.500"
Rear difference is 99.48%, so you you actually pick up a slight bit of gearing advantage. YOU still have to make the decision. It basically comes down to you tolerance to price.
#79
225/45-19 O/A diameter = 84.736"
245/40-19 O/A diameter = 83.933"
245/40-19 O/A diameter = 83.932"
275/35-19 O/A diameter = 83.500"
#81
THANKS TO ALL THAT HELPED! I got the continental extreme dw 245/275 fit perfect, drive awesome, scared myself on some off ramps! Ps my other upgrade were eibach anti roll/sway bar package (front and back). Im set.
#82
Nice choice, sounds like you're to a happy place, glad it worked well.
symphx (10-02-2016)
#83
Which Tires Are Better
Hi Guys,
I'm looking at replacing my tires on my 08 G37 Coupe. I really like the Yoko S.drives and also the Ventus V12 evo.
My tire sizes are 245/35/20 front and 275/30/20 in the back. Tires are running on 20" Vossen rims.
I'm open to suggestions on better tires that are reasonably priced ($1000/set)
Looking for good grip on cornering and good stopping power.
Thanks
Nick
Thanks
Nick
#84
Hi Guys,
Thanks
Nick
Thanks
Nick
bikerjosh
08-19-2015 11:26 PM
2008, 2010, 2454019, continental, coupe, dws, extremecontact, g35, g37, g37s, infiniti, price, quiet, recommended, replacement, tire, tires
