Help Most aggressive stance on stock 19" wheels w/ spacers lowered on coilovers..
I own a G37S coupe.
I'm lowered on BC coilovers with stock 19" wheels and tire sizes.
I need to get new tires and I was hoping to get wider tires in the rear maybe 255+.
What size spacers should I use to get the most aggressive stretch and poke stance for the front and rear without rubbing issues?
The factory 245 tires in the rear on stock 19" wheels has a slight stretch, so would I not be able to put bigger spacers in the rear if I were to put on wider tires?
Pictures of your setup anyone?
Sam IIRC was/is running 245/40's in the front and 275/35's in the rear with 20mm spacers and rubbed in the rears.
Im at 13k miles on my coupe and am starting to debate which tire/spacer combo to go with and am looking at the same things.
I like the stock wheels so Im sticking with them but I wanted to wait until I decided on a tire size before I picked out spacers to match. I want a more flush look, but I dont want them to rub and I dont want to trim the liner. I think im set on H&R spacers as the Ichiba and Kics all have people complaining about vibrations.
Right now Im considering 245/40 front and Im debating between 255/40 and 275/35 in the rear. And Im leaning towards 15mm spacers over 20mm spacers. I think I'd only do 20 if I went with a 255/40 tire in the rear as I think the 275/35's will rub.
Any reason people are going with the 275/35 over the 255/40 tire in the rear? Both are within a fraction of inches of the 240/40 stock diameter?
my setup:
bc coils
15mm ichiba v2 spacers all around
255/40/19 fronts
285/35/19 rears
-2.5 f/-2 r camber
i trimmed about 2" from my fender liner over the top of the tire in the rears and i only rarely rub on large bumps at high speed.
bc coils
255/40/19 fronts
285/35/19 rears
-2.5 f/-2 r camber
Kojack
10-09-2015 05:53 PM
nbast
09-14-2015 12:39 PM
